Tow-Boot issue
I was recently trying to install Mobian (installer doesn't work) and postmarketOS (pmbootstrap fails). Since I couldn't get them to work, I decided to go back to Manjaro but, unfortunately, Tow-Boot refused to boot into USB mass storage mode. It would just buzz four times, buzz another ten times and then power off. It turns out that Tow-Boot requires a bootable OS in eMMC in order to boot into USB mass storage mode even though Tow-Boot is installed in SPI. I ultimately had to install an OS onto a SD card, boot from that and install to eMMC from there in order to get everything working again.
Just posting this here in case anyone else runs into this issue.
Same Problem here and your posting saved my day !!!
Many, many thanks and best regards,
Andrew
  Can't boot Pinephone Pro into Factory Test Build for Hardware Checking jydoxcen 3 736 02-17-2024, 04:04 AM
Last Post: fxc
  Mobian + tow boot + emmc flash = boot loop spropine 4 3,193 12-31-2022, 09:14 AM
Last Post: mburns
  Need to re-write U-boot from Pinephone pro currently in mass rom mode wolverine1 6 2,862 11-20-2022, 05:58 AM
Last Post: wibble
  pinephone pro boot: kernel image not aligned on 64k boundary kmerfeld 2 2,043 08-15-2022, 10:35 AM
Last Post: ajaso
  pinephone pro don’t boot anymore :/ (I erased bootloader by mistake) elode 9 4,868 06-20-2022, 11:16 AM
Last Post: elode
Information Fix PinePhone Pro when unable to boot due to drained battery butjar 7 5,931 05-21-2022, 01:24 PM
Last Post: 98cwitr
  My new Pinephone Pro does not boot any more jlioret 3 2,557 05-21-2022, 12:08 PM
Last Post: 98cwitr
  Tow-Boot on PP vasir 1 1,280 04-28-2022, 05:22 PM
Last Post: vasir
  Power issue with the Pro Freitag 13 6,528 04-25-2022, 06:14 AM
Last Post: LPIZ
  Boot order Barugon 13 7,965 03-11-2022, 09:16 AM
Last Post: kaida
