Tow-Boot on PP
Good day,
I have  a PP Dev edition. Trying to install tow-boot and so far tried everything under the sun.  The phone does not want to boot into Tow-boot.
This is what I am getting:
:: Auto-booting FIT image -> Reading file9330348 bytes read in 981 ms (9.1 MiB)
 -> Attempting boot...## Executing script at 00600000
sha1+
 :: Auto-booting FIT image...
Unknown command 'setexpr' - try 'help'
## Loading kernel from FIT Image at 00600000 ...
Could not find configuration node
ERROR: can't get kernel image!
SCRIPT FAILED: continuing...
libfdt fdt_check_header(): FDT_ERR_BADMAGIC
Card did not respond to voltage select! : -110
Scanning disk mmc@fe310000.blk...
Disk mmc@fe310000.blk not ready
Scanning disk mmc@fe320000.blk...
Scanning disk mmc@fe330000.blk...
Found 6 disks
No EFI system partition
Any idea would be great.
Thanks.
Found it, since the unit I have is a dev ppp, I needed to erase blk2 as per documentation. After that normal boot into the spi flasher without holding the reset button and all is working ok now.
  Can't boot Pinephone Pro into Factory Test Build for Hardware Checking jydoxcen 3 692 02-17-2024, 04:04 AM
Last Post: fxc
  Mobian + tow boot + emmc flash = boot loop spropine 4 3,165 12-31-2022, 09:14 AM
Last Post: mburns
  Need to re-write U-boot from Pinephone pro currently in mass rom mode wolverine1 6 2,822 11-20-2022, 05:58 AM
Last Post: wibble
  Tow-Boot issue Barugon 1 1,333 10-22-2022, 03:22 AM
Last Post: AndrewBlackmiller
  pinephone pro boot: kernel image not aligned on 64k boundary kmerfeld 2 2,023 08-15-2022, 10:35 AM
Last Post: ajaso
  pinephone pro don’t boot anymore :/ (I erased bootloader by mistake) elode 9 4,823 06-20-2022, 11:16 AM
Last Post: elode
Information Fix PinePhone Pro when unable to boot due to drained battery butjar 7 5,893 05-21-2022, 01:24 PM
Last Post: 98cwitr
  My new Pinephone Pro does not boot any more jlioret 3 2,537 05-21-2022, 12:08 PM
Last Post: 98cwitr
  Boot order Barugon 13 7,908 03-11-2022, 09:16 AM
Last Post: kaida
  Needed -- Clarification of Boot SequenceInstructions tckosvic 3 2,172 03-04-2022, 06:20 PM
Last Post: fxc
