[Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present
I'm running ManjaroARM on my PBP. The OS is installed on the eMMC storage. I also have an SD card permanently installed for extra space. Both the eMMC and the SD card have DOS-format partition tables. The SD card is not bootable; the space reserved for a bootloader (in between the MBR and the partition) is zeroed. The SPI flash is blank.
This arrangement used to work fine, but ever since the most recent update to u-boot from Manjaro's official repositories, the laptop won't boot with the SD card present.  This is a complete console log:
U-Boot 2021.10-2 (Dec 25 2021 - 16:31:17 +0000) Manjaro Linux ARM
SoC: Rockchip rk3399
Reset cause: POR
Model: Pine64 Pinebook Pro
DRAM:  3.9 GiB
PMIC:  RK808
MMC:   mmc@fe31000: 3, mmc@fe320000: 1, mmc@fe330000: 0
Loading Environment from SPIFlash... SF: Detected gd25q128 with page size 256 Bytes, erase size 4 KiB, total 16 MiB
*** Warning - bad CRC, using default environment
In:    serial
Out:   vidconsole
Err:   vidconsole
Net:   No ethernet found
starting USB...
Bus usb@fe3a0000: USB OHCI 1.0
Bus usb@fe3e0000: USB OHCI 1.0
scanning bus usb@fe3a0000 for devices... 2 USB Device(s) found
scanning bus usb@fe3e0000 for devices... 3 USB Device(s) found
        scanning usb for storage devices: 0
Hit any key to stop autoboot: 0
Device 0: unknown device
switch to partition #0, OK
mmc1 is current device
Scanning mmc 1:1
libfdt fdt_check_header: FDT_ERR_BADMAGIC
Card did not respond to voltage select! : -110
Scanning disk mmc@fe310000.blk
Disk mmc@fe310000.blk not ready
Scanning disk mmc@fe320000.blk
Scanning disk mmc@fe330000.blk
Found 6 disks
No EFI system partition
BootOrder not defined
EFI boot manager: unknown image
followed by a whole bunch of spew about also being unable to boot off the network (as expected) and a => prompt.
If the SD card is not present, everything is the same up till the "Hit any key to stop autoboot" prompt, after which I get
mmc0(part 0) is current device
Scanning mmc 0:1
Found /extlinux/extlinux.conf
Retrieving file: /extlinux/extlinux.conf
204 bytes read in 14 ms (13.7 KiB/s)
1:      Manjaro ARM
Retrieving file: /initramfs-linux.img
7005870 bytes read in 320 ms (20.9 MiB/s)
Retrieving file: /Image
... etc, etc ...
and the machine boots normally.
So what this looks like to me is that u-boot is no longer falling back to booting from the internal eMMC if the SD card is unbootable. How can I persuade it to start doing that again? It's really annoying to have to pop the SD card out every time I start up the laptop and then put it back after it's booted.
[Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present - by zackw - 01-10-2022, 03:58 PM
  Manjaro Sway Theme Broken Eighty8 1 283 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,760 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 331 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,149 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,229 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 411 12-07-2023, 03:11 PM
  Boot Order in Pinebook Pro food 8 1,242 11-23-2023, 07:37 AM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 902 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 2,022 08-21-2023, 09:10 PM
Last Post: vanessadonald
  Manjaro - HIbernate - brcmfmac clk issue pompeyPinePro 1 767 08-18-2023, 02:06 AM
Last Post: juliamenendez
