Possible to run ArmV7 Apps on Manjaro?
Thanks for you further suggestions, I tried The PacMan GUI after enabling AUR. (then tried YAY)
There were 2 betaflight-configurators in there. one fails before i get the option to modify the buildfile and the output of the other is the exectutable is an amd64 elf file regardless of any modification to the buildfiles to tell it to make aarch64.
Im not really sure of the point of the packages in the user repository as they would only apperar to work for 32/64 bit "desktop" CPUs which are downloadable anyway from the betaflight website or built directly from the source on the website.
I think my best bet is to concentrate on trying to build from source as I have at least been able to "build" a version for armv7 so it should in theory be possible to build for armv8.
Thanks for your pointers, I'll hopefully be able to get my head around the gulpfile process that the original project uses.
So cheers and happy new year
Linux n00b trying to learn.
Brute force and ignorance sometimes works!
| Pinebook Pro + Toshiba OCZ RC100 240GB |
RE: Possible to run ArmV7 Apps on Manjaro? - by gandlers - 01-02-2022, 05:39 AM
  Manjaro Sway Theme Broken Eighty8 1 342 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,813 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 389 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,256 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,366 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 465 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 972 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 2,070 08-21-2023, 09:10 PM
Last Post: vanessadonald
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 2,039 08-21-2023, 09:08 PM
  Manjaro - HIbernate - brcmfmac clk issue pompeyPinePro 1 812 08-18-2023, 02:06 AM
Last Post: juliamenendez
