Possible to run ArmV7 Apps on Manjaro?
This package exists in the AUR, so you can enable the AUR in pamac GTK, search for and mark the package for install, then when it asks you if you want to Edit Build File(s) do so. Change arch=('x86_64') to arch=('x86_64', 'aarch64') or arch=('any') then save and build/install. If it fails, check the errors to see if any dependencies need the arch line altered too.
if you prefer the cli, use yay. it will notice the package is for another arch and ask if you'd like to try building it for aarch64 anyway.
RE: Possible to run ArmV7 Apps on Manjaro? - by tophneal - 12-28-2021, 09:45 AM
  Manjaro Sway Theme Broken Eighty8 1 343 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,815 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 389 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,262 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,366 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 466 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 973 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 2,070 08-21-2023, 09:10 PM
Last Post: vanessadonald
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 2,041 08-21-2023, 09:08 PM
  Manjaro - HIbernate - brcmfmac clk issue pompeyPinePro 1 812 08-18-2023, 02:06 AM
Last Post: juliamenendez
