Possible to run ArmV7 Apps on Manjaro?
Hope everyone has had a good Christmas.
Is it possible to Run 32bit (armv7) software on a 64bit Linux OS (Manjaro in this case). Goggling suggests that it is possible by enabling some sort of compatibility mode
Im trying to get betaflight-configurator runing on my PineBook Pro.
There isnt a release built for Linux on arm, but there are instructions for building for armv7 although this isnt officially supported.
I have managed to blindly follow the instructions and built for armv7 but it doesnt run on Manjaro.
I don t know if it is feasible to modify the the "gulpfile" to add an armv8 option or whether there is some wat to run the armv7 build on Manjaro by enabling the compatibility mode.
Any advice or pointers from bigger brains than mine would be greatly appreciated.
Cheers
G
Linux n00b trying to learn.
Brute force and ignorance sometimes works!
| Pinebook Pro + Toshiba OCZ RC100 240GB |
Possible to run ArmV7 Apps on Manjaro? - by gandlers - 12-27-2021, 06:19 AM
  Manjaro Sway Theme Broken Eighty8 1 296 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,767 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 347 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,166 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,239 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 419 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 907 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 2,026 08-21-2023, 09:10 PM
Last Post: vanessadonald
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 1,986 08-21-2023, 09:08 PM
  Manjaro - HIbernate - brcmfmac clk issue pompeyPinePro 1 777 08-18-2023, 02:06 AM
Last Post: juliamenendez
