Is there a way to turn off Wifi completely?
(12-21-2021, 08:09 AM)jirow Wrote: From this thread
How does the kill switch work?
  https://forum.pine64.org/showthread.php?tid=9990
I found that the ON / OFF information of the private switch is stored in the memory of the keyboard. This means that private switch information will be lost if the PineBook's main battery is completely discharged.
If the PinBook is started with the private switch turned off, it may be illegal under the Radio Law in Japan. This is not good.
Is there a way to force the private switch on when the pinebook boots from 0% battery? I'm sorry to ask you more questions even though the above reply has suggested a fairly effective method.
Could you give me some hints?
The privacy switches, including the WiFi, are stored in Non-Volatile memory. This chip is physically separate from the keyboard controller and is wired to an I2C bus if I remember correctly. If the keyboard processor comes up, it reads the privacy switch configuration and programs the external device power as appropriate.
The default power state is almost certainly off. So if the keyboard processor fails to boot, WiFi power will likely stay off.
You can find the schematics here;
Pine64 Wiki - Pinebook Pro - Schematics
The page for the keyboard controller is 19, and the privacy switch storage chip is the lower right one, U7005, if I remember correctly. It's tiny, I think like 256 bytes. But, more than enough for it's purpose.
Arwen Evenstar
Princess of Rivendale
RE: Is there a way to turn off Wifi completely? - by Arwen - 12-21-2021, 11:46 AM
  Both hinges completely failed phuzy 20 11,131 01-02-2024, 02:03 AM
Last Post: Uturn
  Kernel Not Detecting Wifi tallfrye 10 1,078 01-01-2024, 06:57 AM
  Connection to WiFi with OWE IhorOlkhovskyi 1 1,412 09-01-2022, 08:48 AM
Last Post: IhorOlkhovskyi
  RTL8811AU usb wifi for pbpro vlut 0 1,324 12-02-2021, 05:23 AM
Last Post: vlut
  Mini-Howto: ROCK64 USB 3.0 WIFI Adapter (Rabbit-ear) on Manjaro Dendrocalamus64 1 2,422 11-14-2021, 03:41 PM
Last Post: Dendrocalamus64
  Wifi disconnecting after few minutes hellojack 0 1,405 09-16-2021, 02:50 AM
Last Post: hellojack
  Advice on increasing WIFI range stozi 2 4,105 03-29-2021, 06:57 AM
Last Post: barray
  Curious about problem with PBP Wifi kendew 3 4,776 01-14-2021, 11:16 AM
Last Post: clover
  Pinebook Pro won't turn on codebreaker 62 77,842 10-27-2020, 08:27 AM
Last Post: cefre00
  Privacy switches - cutting power to wifi card as400 1 2,812 08-10-2020, 09:48 AM
Last Post: belfastraven
