Is there a way to turn off Wifi completely?
From this thread
How does the kill switch work?
https://forum.pine64.org/showthread.php?tid=9990
I found that the ON / OFF information of the private switch is stored in the memory of the keyboard. This means that private switch information will be lost if the PineBook's main battery is completely discharged.
If the PinBook is started with the private switch turned off, it may be illegal under the Radio Law in Japan. This is not good.
Is there a way to force the private switch on when the pinebook boots from 0% battery? I'm sorry to ask you more questions even though the above reply has suggested a fairly effective method.
Could you give me some hints?
RE: Is there a way to turn off Wifi completely? - by jirow - 12-21-2021, 08:09 AM
  Both hinges completely failed phuzy 20 10,980 01-02-2024, 02:03 AM
Last Post: Uturn
  Kernel Not Detecting Wifi tallfrye 10 993 01-01-2024, 06:57 AM
  Connection to WiFi with OWE IhorOlkhovskyi 1 1,400 09-01-2022, 08:48 AM
Last Post: IhorOlkhovskyi
  RTL8811AU usb wifi for pbpro vlut 0 1,321 12-02-2021, 05:23 AM
Last Post: vlut
  Mini-Howto: ROCK64 USB 3.0 WIFI Adapter (Rabbit-ear) on Manjaro Dendrocalamus64 1 2,405 11-14-2021, 03:41 PM
Last Post: Dendrocalamus64
  Wifi disconnecting after few minutes hellojack 0 1,399 09-16-2021, 02:50 AM
Last Post: hellojack
  Advice on increasing WIFI range stozi 2 4,082 03-29-2021, 06:57 AM
Last Post: barray
  Curious about problem with PBP Wifi kendew 3 4,741 01-14-2021, 11:16 AM
Last Post: clover
  Pinebook Pro won't turn on codebreaker 62 77,274 10-27-2020, 08:27 AM
Last Post: cefre00
  Privacy switches - cutting power to wifi card as400 1 2,799 08-10-2020, 09:48 AM
Last Post: belfastraven
