Is there a way to turn off Wifi completely?
(12-20-2021, 05:57 AM)maxjrh Wrote: The WiFi can be completely disabled with the privacy switches https://wiki.pine64.org/wiki/Pinebook_Pr...y_Switches
You can disable WiFi once, and then it will stay disabled across reboots.
Thank you for your reply
Private Switch is a great answer! I didn't read the Wiki very much. Thank you for teaching.
It's great that a simple keyboard shortcut will stop the current supply to the wifi module.
Messages In This Thread |
RE: Is there a way to turn off Wifi completely? - by jirow - 12-20-2021, 06:38 PM
Possibly Related Threads… |
Thread |
Author |
Replies |
Views |
Last Post |
Both hinges completely failed |
phuzy |
20 |
11,119 |
01-02-2024, 02:03 AM
Last Post: Uturn
Kernel Not Detecting Wifi |
tallfrye |
10 |
1,067 |
01-01-2024, 06:57 AM
Connection to WiFi with OWE |
IhorOlkhovskyi |
1 |
1,412 |
09-01-2022, 08:48 AM
Last Post: IhorOlkhovskyi
RTL8811AU usb wifi for pbpro |
vlut |
0 |
1,324 |
12-02-2021, 05:23 AM
Last Post: vlut
Mini-Howto: ROCK64 USB 3.0 WIFI Adapter (Rabbit-ear) on Manjaro |
Dendrocalamus64 |
1 |
2,422 |
11-14-2021, 03:41 PM
Last Post: Dendrocalamus64
Wifi disconnecting after few minutes |
hellojack |
0 |
1,405 |
09-16-2021, 02:50 AM
Last Post: hellojack
Advice on increasing WIFI range |
stozi |
2 |
4,104 |
03-29-2021, 06:57 AM
Last Post: barray
Curious about problem with PBP Wifi |
kendew |
3 |
4,773 |
01-14-2021, 11:16 AM
Last Post: clover
Pinebook Pro won't turn on |
codebreaker |
62 |
77,810 |
10-27-2020, 08:27 AM
Last Post: cefre00
Privacy switches - cutting power to wifi card |
as400 |
1 |
2,812 |
08-10-2020, 09:48 AM
Last Post: belfastraven
