Help how to mount SD-Card
I think it's formatted as exfat - at least on my desktop 'file -sL' says 'DOS/MBR boot sector' when run against an exfat formatted partition. The kernel on my desktop supports exfat so I can mount it, but it looks like PmOS may not. Perhaps look for an exfat package to install suitable kernel driver and userspace tools? If those don't exist then you'll have to reformat in a format it can mount.
Help how to mount SD-Card - by chadwick - 11-19-2021, 04:09 AM
RE: Help how to mount SD-Card - by wibble - 11-19-2021, 05:01 AM
RE: Help how to mount SD-Card - by chadwick - 11-22-2021, 12:46 AM
RE: Help how to mount SD-Card - by Juergen - 11-20-2021, 03:31 AM
RE: Help how to mount SD-Card - by wibble - 11-22-2021, 07:02 AM
RE: Help how to mount SD-Card - by chadwick - 11-25-2021, 03:37 AM
RE: Help how to mount SD-Card - by wibble - 11-25-2021, 09:15 AM
RE: Help how to mount SD-Card - by chadwick - 11-26-2021, 05:09 AM
RE: Help how to mount SD-Card - by chadwick - 11-30-2021, 11:12 PM
  How can I get the permissions to write to the external SD card ...? Peter Gamma 9 1,893 10-20-2023, 12:32 PM
Last Post: Peter Gamma
  How to write the the external SD card with Abword? Peter Gamma 0 504 08-27-2023, 01:10 AM
  How can I open an Abiword file from an external SD card with Abiword? Peter Gamma 5 2,152 08-25-2023, 02:05 AM
  Unable to mount root partition PostmarketOS lanawwas 0 2,904 09-06-2020, 07:42 AM
Last Post: lanawwas
  pmaports root & boot mount issue dustfinger 0 2,005 07-07-2020, 09:43 AM
Last Post: dustfinger
  PP boots into factory test even if flashed sd card is inserted hapster 5 6,565 04-13-2020, 02:34 PM
Last Post: MartijnBraam
  terminal command for sd card size pnphn 5 6,805 04-02-2020, 12:51 PM
Last Post: someGermanGuy
