Chatty, SMS does not work - could hardware be at fault?
#37
(11-01-2021, 05:29 AM)fernando_c_m Wrote: adb server has to be started as root. You are issuing the commands as user.
If you use the flash script you have to use sudo. Otherwise it will fail, since there are sudo commands in there
Thank you, kqlnut , fernando_c_m !
That made it work. My problem appears to be solved, the modem only crashed once over the past two days.
RE: Chatty, SMS does not work - could hardware be at fault? - by AntonReiser - 11-02-2021, 03:42 AM
  Chatty Matrix Decryption Key jojuma 2 307 02-26-2024, 12:48 PM
  Jabber with chatty user641 2 1,018 11-12-2023, 02:10 AM
Last Post: user641
  gnome-control-center: segmentation fault on startup jojuma 4 1,154 09-12-2023, 08:49 AM
Last Post: jojuma
  wwan0 (SIM interface) doesn't work with OpenVPN nickolas 6 2,203 09-05-2023, 11:16 AM
Last Post: nickolas
  Chatty does not work after suspend mode user641 4 1,989 07-18-2023, 10:43 AM
Last Post: alaraajavamma
  reset wifi hardware/driver when it dies through console on pp? tuxcall 4 1,944 07-18-2023, 08:54 AM
Last Post: junelung
  Wifi doesn't work after update nickolas 2 1,279 04-14-2023, 10:07 AM
Last Post: nickolas
  Most recent Mobian image or installer image known to work? DrPlamsa 13 5,110 02-26-2023, 11:47 PM
Last Post: SukiiPooru
  beware chatty 0.7.0~rc0-1 treebeard 6 2,676 11-06-2022, 04:51 PM
Last Post: treebeard
Exclamation The webcam doesn't work in Firefox anonymous 0 760 11-06-2022, 01:45 PM
Last Post: anonymous
