Chatty, SMS does not work - could hardware be at fault?
Just a stab in the dark, but you could check which modem firmware you are on and try upgrading it. Maybe also try the alternative firmware (which has been working well for me; easy to follow instructions for flashing can be found here). I don't belive this would have a direct effect on SMS handling, but it could be worth a try.
RE: Chatty, SMS does not work - could hardware be at fault? - by kqlnut - 09-19-2021, 04:10 AM
  Chatty Matrix Decryption Key jojuma 2 400 02-26-2024, 12:48 PM
  Jabber with chatty user641 2 1,104 11-12-2023, 02:10 AM
Last Post: user641
  gnome-control-center: segmentation fault on startup jojuma 4 1,273 09-12-2023, 08:49 AM
Last Post: jojuma
  wwan0 (SIM interface) doesn't work with OpenVPN nickolas 6 2,300 09-05-2023, 11:16 AM
Last Post: nickolas
  Chatty does not work after suspend mode user641 4 2,072 07-18-2023, 10:43 AM
Last Post: alaraajavamma
  reset wifi hardware/driver when it dies through console on pp? tuxcall 4 2,026 07-18-2023, 08:54 AM
Last Post: junelung
  Wifi doesn't work after update nickolas 2 1,333 04-14-2023, 10:07 AM
Last Post: nickolas
  Most recent Mobian image or installer image known to work? DrPlamsa 13 5,308 02-26-2023, 11:47 PM
Last Post: SukiiPooru
  beware chatty 0.7.0~rc0-1 treebeard 6 2,810 11-06-2022, 04:51 PM
Last Post: treebeard
Exclamation The webcam doesn't work in Firefox anonymous 0 791 11-06-2022, 01:45 PM
Last Post: anonymous
