Other boot options than Sdcard for linux 5.x kernel?
All due respect, using some other u-boot (that did not come with Armbian) is not really "using Armbian."  lol
Armbian comes with u-boot, in fact such low level customizations are the very raison d'être for Armbian in the first place.
There is a special tool however for installing to other media than sd card, called nand-sata-install (which is also available from armbian-config).  So, just burn your image to sd card (making sure to take all usual precautions), boot into it, then use those tools to install to the eMMC (or wherever you like).
Cheers,
TRS-80
Protocols, not Platforms
RE: Other boot options than Sdcard for linux 5.x kernel? - by TRS-80 - 07-14-2021, 02:37 PM
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 1 516 03-25-2024, 12:12 PM
  Boot/Shutdown on timer captainmorgan 8 6,118 11-01-2023, 12:08 PM
Last Post: Nikolay_Po
Exclamation Ethernet regression on Linux Kernel 6.5.4? Deathcrow 3 847 09-22-2023, 04:27 AM
Last Post: diederik
  Installing CH431SER on Ayufan 0.9.14: gitlab-ci-linux-build-159 Thisone 4 1,330 07-14-2023, 04:22 AM
Last Post: hunderteins
Question How do I compile an arbitrary kernel for U-Boot? Valenoern 3 1,137 06-16-2023, 10:54 AM
Last Post: CounterPillow
  Linux laptop does not detect the board when plugged in via USB soupy 1 4,024 04-13-2023, 03:01 AM
Last Post: Reynold Grady
  RockPro64 boot questions misterc 3 1,606 01-13-2023, 06:21 PM
Last Post: misterc
  Is some u-boot required on the SPI for installing debian with the official installer? callegar 1 1,359 10-25-2022, 10:07 AM
Last Post: ratzzupaltuff
  RockPro64 linux console video mode callegar 0 889 09-06-2022, 02:32 PM
Last Post: callegar
  [OS] SkiffOS and Buildroot for Rockpro64 w/ 5.17 kernel paralin1 1 1,850 05-08-2022, 03:26 PM
Last Post: paralin1
