Disable the Power Button or make it do something else
(06-01-2021, 01:26 PM)jms429 Wrote: Hi. I did 1 and for 2 I added this line to the shutdown code:
# Set shut down, restart and locking features
bindsym $mod+0 mode "$mode_system"
bindsym XF86PowerOff mode "$mode_system"
My only thought is maybe its a different key code on ANSI keyboard?
Your response is quite incomplete.
Does 1 (inhibit power button) works ? after editing logind.conf, systemctl restart systemd-logind.service, or reboot.
Does your bind mod+0 works ? If it doesnt, not a problem of keycode, but code, in your conf.
Assuming you use i3, you must use x11, so try use xev to get your keycodes (mine is ansi too).
RE: Disable the Power Button or make it do something else - by rimaille - 06-01-2021, 08:42 PM
  Unable to make a bootable microSD card myself600 15 5,719 09-27-2022, 01:45 PM
Last Post: myself600
  Loud distorted speaker sound when connecting to power supply myself600 2 1,238 09-21-2022, 12:11 PM
  How to make manjaro sleep or hibernate? KDE? regretfulpineuser 0 1,002 06-20-2022, 12:56 AM
Last Post: regretfulpineuser
  red/green power led not working with kernel 5.14 alchemist 4 3,843 11-04-2021, 04:09 AM
Last Post: alchemist
  Power LED flashing red/green... appelgriebsch 3 5,217 09-05-2021, 07:59 PM
Last Post: dealie
Question How do I disable autologin on TwisterOS? TDC_PBP 3 3,438 08-27-2021, 11:44 AM
Last Post: TDC_PBP
  Pinebook Pro Manjaro Power Savinng Tips HelpMyBatteryIsDraining 1 2,500 06-15-2021, 08:42 AM
Last Post: moonwalkers
  Make it easy? wdt 0 1,709 09-10-2020, 10:05 PM
Information How to make the Manjaro Gnome image update TDC_PBP 2 4,357 07-13-2020, 02:24 PM
Last Post: TDC_PBP
  power button bsammon 3 4,676 03-25-2020, 02:20 PM
Last Post: bsammon
