Pinebook Pro Manjaro Power Savinng Tips
How can I minimize power usage in Manjaro(e.g. turning off CPU cores, lowering default brightness, etc.)
(06-14-2021, 07:01 PM)HelpMyBatteryIsDraining Wrote: How can I minimize power usage in Manjaro(e.g. turning off CPU cores, lowering default brightness, etc.)
The same way you can do that in almost any other Linux distro. Your UI options will depend on the desktop environment you choose to run - e.g. in KDE there is a slider when you click on a battery icon in your tray. You should be able to use your keyboard too, Fn+F1/Fn+F2 should be the keys. As to turning off CPU cores - you wanna play around with values in /sys/devices/system/cpu/cpu#/online - you can read them, and, as root, write to them.
Generally though, don't be afraid to use search engines for such basic questions - they won't bite you, and searching for something like "linux turn off cpu core" or "manjaro adjust display brightness" will yield exactly what you're looking for among the very first few results, and typically much faster than if you wait for the answers on a forum.
This message was created with 100% recycled electrons
  Debian on Pinebook Pro u974615 8 442 03-22-2024, 03:57 PM
Last Post: u974615
  Manjaro Sway Theme Broken Eighty8 1 166 03-08-2024, 08:41 AM
  Pinebook Pro upgrading from the factory image yamsoup 12 1,113 02-22-2024, 04:02 PM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,605 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 213 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 1,914 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 1,979 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 86,615 12-08-2023, 11:25 PM
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 291 12-07-2023, 03:11 PM
  Boot Order in Pinebook Pro food 8 992 11-23-2023, 07:37 AM
