Loud distorted speaker sound when connecting to power supply
Does anybody know what is causing this? It happened today after booting back to eMMC from SD. Both have the same system image flashed: Manjaro Plasma 22.08 generic
https://imgur.com/a/5Ts2UWc
It's still happening! It disappears early after the first speaker "pop". I speculate it may be caused by a recent system update.
A somewhat similar issue happened today:
https://imgur.com/a/EIsIVW1
Edit: This happens after resuming from sleep (lid closed) when audio stops working, which should be related to https://forum.pine64.org/showthread.php?tid=10496. The suggested workaround
sudo tee /sys/bus/i2c/drivers/es8316/{un,}bind <<< 1-0011
doesn't help.
  Sound on Armbian Bram 1 885 04-01-2023, 03:16 PM
Last Post: TRS-80
  Hibernation and Speaker Sound Issues, First Month of PBP kebab 7 2,964 11-02-2022, 02:33 PM
Last Post: kebab
  red/green power led not working with kernel 5.14 alchemist 4 3,770 11-04-2021, 04:09 AM
Last Post: alchemist
  reset sound after suspend to memory (deep sleep) Der Geist der Maschine 16 16,921 10-18-2021, 07:31 PM
Last Post: Syonyk
  Power LED flashing red/green... appelgriebsch 3 5,123 09-05-2021, 07:59 PM
Last Post: dealie
  Disable the Power Button or make it do something else User 22018 6 6,532 08-20-2021, 06:36 PM
Last Post: xmixahlx
  Enabling spekaer/Connecting to bluetooth from command line axisarm 1 1,945 08-06-2021, 04:29 PM
Last Post: nfms
  Sound stuttering on Manjaro gnome after latest kernel upgrade? pjsf 0 1,783 07-13-2021, 10:37 PM
Last Post: pjsf
  Pinebook Pro Manjaro Power Savinng Tips HelpMyBatteryIsDraining 1 2,448 06-15-2021, 08:42 AM
Last Post: moonwalkers
Music No sound on PBP default installation ivek 9 9,252 05-09-2021, 05:58 PM
Last Post: binholz
