Anyone using a hardware token?
(05-02-2021, 11:53 PM)pajux Wrote:
(05-02-2021, 07:23 AM)p121458 Wrote: Nice! Looks promising. You made the blocks black right to masquerade? Or are these some artifacts in the app?
Just read a thread on this forum about delamminating screens.....I'm in doubt. But good the sofware part seems to be doable for me.
I did not retouch the image in any way, the screenshot is exactly how it looked on my screen, so yes, it's not perfectly fitting the Pinephone/mobile form factor...  But it fit way better than I expected, probably owing to the app using QML and modern QT libs.
I tried installing the yubioath-desktop package on my Mobian Pinephone, and I do not have the black blocks in your screenshot.
I am attaching unmodified screenshots, one before I plugged my Yubikey into the hub, one right after, then two showing the options for adding an account (scan v. manual).
If you are planning on running Mobian, note that hub ("dock") supplied with the convergence version of the phone (the $200/3GB RAM/32GB EMMC version) will not supply more than 0.5Amps to the phone.  (See this thread.)  If this bothered me enough, I would try the Manjaro-KDE OS on a MicroSD.
Also, my screen is fine, though I have only had the phone two months.  There are some bugs and glitches, but I am amazed by the Pinephone.
Anyone using a hardware token? - by p121458 - 04-29-2021, 02:46 PM
RE: Anyone using a hardware token? - by pajux - 04-29-2021, 06:32 PM
RE: Anyone using a hardware token? - by p121458 - 04-30-2021, 12:14 AM
RE: Anyone using a hardware token? - by pajux - 04-30-2021, 07:37 PM
RE: Anyone using a hardware token? - by p121458 - 05-01-2021, 01:15 AM
RE: Anyone using a hardware token? - by pajux - 05-01-2021, 06:24 PM
RE: Anyone using a hardware token? - by p121458 - 05-02-2021, 07:23 AM
RE: Anyone using a hardware token? - by pajux - 05-02-2021, 11:53 PM
RE: Anyone using a hardware token? - by mew2020 - 05-03-2021, 10:34 AM
RE: Anyone using a hardware token? - by pajux - 05-03-2021, 08:24 PM
RE: Anyone using a hardware token? - by mew2020 - 05-05-2021, 02:31 PM
RE: Anyone using a hardware token? - by biketool - 05-13-2021, 04:42 AM
RE: Anyone using a hardware token? - by EuvzO8 - 01-15-2022, 12:07 PM
RE: Anyone using a hardware token? - by biketool - 01-17-2022, 03:24 AM
  reset wifi hardware/driver when it dies through console on pp? tuxcall 4 1,961 07-18-2023, 08:54 AM
Last Post: junelung
  Hardware VIdeo Acceleration on Mobian biketool 3 2,604 06-21-2022, 01:01 PM
  Chatty, SMS does not work - could hardware be at fault? AntonReiser 36 25,740 11-02-2021, 03:42 AM
Last Post: AntonReiser
  Is there a list of software/Hardware errors Franze_m 6 5,238 02-24-2021, 12:07 PM
  Is the A64’s true hardware random generator activated in Mobian’s 5.10 kernel build? LibrePhoneUser 3 4,047 01-17-2021, 12:44 PM
Last Post: LibrePhoneUser
