Hardware VIdeo Acceleration on Mobian
It has finally happened, soon we will be able to play a few hours of multimedia without using up our whole battery.
https://briandaniels.me/2021/06/27/hardw...phone.html
and now in a GTK app called CLapper, hope it makes it into the repos soon as well as either in a hardware abstraction layer for the OS or as a build target for the big video players like Totem, VLC, and Kodi.
The blog is almost a year old. What can our community do to expedite the project?
(04-17-2022, 04:39 PM)vusra Wrote: The blog is almost a year old.  What can our community do to expedite the project?
Firstly use these to be in live communication with the Mobian community
https://wiki.mobian-project.org/#communication-channels
sometimes I feel like we are isolated on the pine64 boards where there is only a loose connection to Mobian.
What can we do?  Those with the skills can contribute or fork the work on Clapper which seems to be the complete player which includes the gstreamer player demonstrated. https://github.com/Rafostar/clapper
Other devs can be encouraged to review the accelerated code but it might also be good to encourage Mobian to start moving all opengl compatible app compiles to target the system's hardware acceleration.
Just a FYI Clapper gstreamer plugin based video player is available now as a flatpak, I am not sure if the flatpak version is the GPU accelerated or if a special build was made for the link above.
Quick testing shows a little heat, smooth playback, subtitle support, plays a wide range of video formats(way better than the included Videos app based on Totem) .
This app is mobile optimized so appears with other mobile apps in phosh; it is easily accesses the SD card dir and open a locked/encrypted SD.
I have not tried any high bit-rate files and I have not done a battery life test but it already performs and interfaces better than any other player on a PP including Kodi and VLC.
I have not really watched video on a mobile device in quite a long time though I like having the option, it looks like I have a new favorite player.
Mobian is getting more everyday-driver friendly, we will have to see how this player affects battery life.
<edit> it looks like this flatpak version has the brian daniels opengl PP GPU(ARM Mali 400 MP2 GPU) accel baked in https://github.com/Rafostar/clapper see the bottom of the page "Big thanks to bridadan and Uniformbuffer3 for helping with testing V4L2 and NVDEC hardware acceleration methods." https://briandaniels.me/2021/07/06/hardw...apper.html
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 17 2,101 Yesterday, 05:47 AM
Last Post: diederik
  Mobian repository status henrythemouse 16 8,803 04-10-2024, 10:02 AM
Last Post: diederik
  cant verify mobian image at website gnugpg penguins_rule 0 136 03-18-2024, 08:54 PM
Last Post: penguins_rule
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,015 11-22-2023, 11:46 AM
Last Post: aLoop100o
  What actions needed to keep on mobian testing user641 3 1,838 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 639 09-01-2023, 11:29 AM
Last Post: Mahgue
  reset wifi hardware/driver when it dies through console on pp? tuxcall 4 1,901 07-18-2023, 08:54 AM
Last Post: junelung
  how to update mobian over tor vusra 13 6,938 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,910 07-09-2023, 01:37 AM
Last Post: vusra
  Using Nativefier on PP64 with Mobian paulcarton 0 638 07-05-2023, 03:57 AM
Last Post: paulcarton
