Is the A64’s true hardware random generator activated in Mobian’s 5.10 kernel build?
The 5.10 kernel release brought support for the Pinephone A64 processor’s true hardware random number generator under the sun8i-ce module. However, even after I load the module I am not getting a working /dev/hwrng.
The patch adding this support to the 5.10 kernel provides a new kernel option that must be activated before building the kernel:
+config CRYPTO_DEV_SUN8I_CE_TRNG
+    bool "Support for Allwinner Crypto Engine TRNG"
+    depends on CRYPTO_DEV_SUN8I_CE
+    select HW_RANDOM
+    help
+      Select this option if you want to provide kernel-side support for
+      the True Random Number Generator found in the Crypto Engine.
Is this option selected in Mobian's kernel build? If not, could I request that it be activated?
You may need to file this on the mobian bug tracker
+    select HW_RANDOM
+    help
No, Mobian stock kernel does not have this set. You can easily find out for yourself:
mobian@pinephone:~$ zgrep SUN8I_CE /proc/config.gz
CONFIG_CRYPTO_DEV_SUN8I_CE=m
CONFIG_CRYPTO_DEV_SUN8I_CE_DEBUG=y
# CONFIG_CRYPTO_DEV_SUN8I_CE_HASH is not set
# CONFIG_CRYPTO_DEV_SUN8I_CE_PRNG is not set
# CONFIG_CRYPTO_DEV_SUN8I_CE_TRNG is not set
Thanks, I have filed a bug on the Mobian tracker. Sorry that I forgot all about /proc/config to see what kernel options had been selected at build time.
  Mobian repository status henrythemouse 16 8,730 04-10-2024, 10:02 AM
Last Post: diederik
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 15 2,000 03-25-2024, 09:07 AM
Last Post: anonymous
  cant verify mobian image at website gnugpg penguins_rule 0 131 03-18-2024, 08:54 PM
Last Post: penguins_rule
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 1,990 11-22-2023, 11:46 AM
Last Post: aLoop100o
  What actions needed to keep on mobian testing user641 3 1,815 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 633 09-01-2023, 11:29 AM
Last Post: Mahgue
  reset wifi hardware/driver when it dies through console on pp? tuxcall 4 1,888 07-18-2023, 08:54 AM
Last Post: junelung
Big Grin An early xmas present: 6.1 kernel treebeard 28 9,940 07-18-2023, 03:14 AM
Last Post: gischpelino
  how to update mobian over tor vusra 13 6,879 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,896 07-09-2023, 01:37 AM
Last Post: vusra
