auto-brightness problem phone screen going to completely dim
(05-09-2021, 03:37 PM)mudflap Wrote:
(03-24-2021, 05:13 AM)acrux Wrote:
(03-23-2021, 09:53 PM)DonF22 Wrote: Hi, I've applied all recent updates but my Pine Phone KDE Plasma (community edition) keeps automatically going auto-brightness to completely dim.
Is anybody else having this problem and what is the solution?
Did you try to adjust display timeout setting using Settings -> Screen?
I did and got the same situation as you did.
I solved that to manually editing the file /.config/powermanagementprofilesrc
It seems that the Screen settings app inserted there [BrightnessControl] value 0.5, which is not 50 % but 0.5 in a scale of hundred or 0.5% Big Grin. Also needed to edit the screen timeout values to reasonable ones.
how do you open /.config/powermanagementprofilesrc ? can I do it on the phone itself? or do I need to plug it into the dock? I found the .config folder, but it is greyed out and says "nothing here" when I open it. do I need to use terminal and sudo commands?
Just replied to you on the other thread: https://forum.pine64.org/showthread.php?tid=13690&page=2
RE: auto-brightness problem phone screen going to completely dim - by Timothy_Ecc - 05-11-2021, 07:00 PM
  Arch auto mount usb example Lazy_one 2 4,564 10-06-2023, 09:36 AM
Last Post: luppivega
  Phone calls with no sound user641 14 12,485 03-12-2023, 11:43 AM
Last Post: alpineduck
  phone and plasma oihantto64 3 3,645 10-22-2022, 04:51 PM
Last Post: Chief
  Phone no longer works at all AndyM 2 2,620 10-19-2022, 12:08 AM
Last Post: AndyM
  Scaling problem Arch Linux Phosh Chief 7 6,154 09-27-2022, 12:31 PM
Last Post: Chief
  Screen rotation lordearl 9 11,672 08-29-2022, 02:23 AM
Last Post: cone99
  Incoming calls only vibrate, phone is not ringing lacriz 4 5,160 05-31-2022, 11:40 PM
Last Post: hannescam
  archplasma: phone et discover broken? oihantto64 3 3,756 05-14-2022, 03:38 PM
Last Post: oihantto64
  Last update bricked my pine phone :( lacriz 6 6,382 01-25-2022, 07:52 AM
Last Post: kqlnut
  "file too short" problem causing many sofware dependencies to fail pineuser0 2 4,183 10-31-2021, 09:57 AM
Last Post: pineuser0
