auto-brightness problem phone screen going to completely dim
Hi, I've applied all recent updates but my Pine Phone KDE Plasma (community edition) keeps automatically going auto-brightness to completely dim.
Is anybody else having this problem and what is the solution?
Settings Slider keeps scooting to the left and the phone screen goes completely dark.
thanks
Don
(03-23-2021, 09:53 PM)DonF22 Wrote: Hi, I've applied all recent updates but my Pine Phone KDE Plasma (community edition) keeps automatically going auto-brightness to completely dim.
thanks
Don
Yup, seems to me a phosh feature. Only option at present us to do brightness manually.
Did you try to adjust display timeout setting using Settings -> Screen?
I did and got the same situation as you did.
I solved that to manually editing the file /.config/powermanagementprofilesrc
It seems that the Screen settings app inserted there [BrightnessControl] value 0.5, which is not 50 % but 0.5 in a scale of hundred or 0.5% Big Grin. Also needed to edit the screen timeout values to reasonable ones.
Editing the file worked, I figured out nano.
I didn't see the screen timeout values tho, what are they called?
Thanks very much
(03-29-2021, 03:53 PM)DonF22 Wrote: Editing the file worked, I figured out nano.
They are in different [DimDisplay] sections and called "idleTime"
how do you open /.config/powermanagementprofilesrc ? can I do it on the phone itself? or do I need to plug it into the dock? I found the .config folder, but it is greyed out and says "nothing here" when I open it. do I need to use terminal and sudo commands?
Just replied to you on the other thread: https://forum.pine64.org/showthread.php?tid=13690&page=2
  Arch auto mount usb example Lazy_one 2 9,482 10-06-2023, 09:36 AM
Last Post: luppivega
  Phone calls with no sound user641 14 20,333 03-12-2023, 11:43 AM
Last Post: alpineduck
  phone and plasma oihantto64 3 6,102 10-22-2022, 04:51 PM
Last Post: Chief
  Phone no longer works at all AndyM 2 4,210 10-19-2022, 12:08 AM
Last Post: AndyM
  Scaling problem Arch Linux Phosh Chief 7 10,412 09-27-2022, 12:31 PM
Last Post: Chief
  Screen rotation lordearl 9 17,103 08-29-2022, 02:23 AM
Last Post: cone99
  Incoming calls only vibrate, phone is not ringing lacriz 4 7,496 05-31-2022, 11:40 PM
Last Post: hannescam
  archplasma: phone et discover broken? oihantto64 3 5,769 05-14-2022, 03:38 PM
Last Post: oihantto64
  Last update bricked my pine phone :( lacriz 6 9,749 01-25-2022, 07:52 AM
Last Post: kqlnut
  "file too short" problem causing many sofware dependencies to fail pineuser0 2 6,182 10-31-2021, 09:57 AM
Last Post: pineuser0
