Battery Power
(06-12-2016, 06:00 PM)pfeerick Wrote:
(06-11-2016, 10:55 PM)clackamas Wrote: The main question I have is do I need to add a ploy (or other) fuse (as he describes) to protect from short circuits?
Hi Henry,
Since you're using multiple pine64 boards in an array, I would be tempted to put standard glass fuses inline with the power supply line into each pine64. A polyfuse is good as it self-resets, but that can also hide a problem, unless you know that the device has triggered the fuse and why. Plain glass fuses are cheap, and if you were to put 1.5/2A fuses on each pine64, I don't see why they would blow those fuses unless something went wrong (as I have yet to see a properly working pine64 need more than 800ma @ 5v for just the main board+wifi, without the LCD or peripherals on the USB).
At an absolute minimum, you would want a single fuse between the power supply and the cluster, rated at just more than what you expect the maximum power from the cluster to be (for 5 pines, a fuse between 7.5A -10A would do), so the power supply doesn't get overloaded (although modern computer power supplies do have good self-protection circuitry in them, and generally shut down if anything goes wrong, but it's never good to blindly rely on that!).
Pete
Thank you.  That is very helpful.  I am trying to keep the cabling simple so, the glass fuses meet that criteria.  I eventually play to build a 33 node cluster but the 5 boards are to prototype.
Battery Power - by clackamas - 06-11-2016, 10:55 PM
RE: Battery Power - by tllim - 06-12-2016, 12:21 AM
RE: Battery Power - by pfeerick - 06-12-2016, 06:00 PM
RE: Battery Power - by clackamas - 06-13-2016, 02:18 PM
  Which Power Supply Unit for Pine64 A64 DB V1.1 2GB REV B (year 2016)? databaseprogrammer 1 3,103 07-03-2021, 01:29 AM
Lightbulb Alternate Power DC-IN on the Euler Bus also with PI filter for batt operation MarkHaysHarris777 13 25,586 12-19-2020, 09:53 PM
Last Post: evilpete
  PineA64 battery in Germany (specifications or alternatives) burningkrome 0 3,133 12-02-2018, 04:10 AM
Last Post: burningkrome
  Once Again: Power Supply problems I guess (Pine A64+ locking up) marcelser 0 3,530 06-04-2018, 03:11 PM
Last Post: marcelser
  Power supply problems. larsen8989 5 9,360 05-03-2018, 09:01 PM
  solar power on a Pine64 tablet Little_Johnny 11 15,822 03-20-2018, 12:01 AM
Last Post: pfeerick
  Power up HDDs c4tich 3 6,359 03-18-2017, 09:18 AM
Last Post: Luke
  Provide power in via Pi-2 header BenCranston 22 29,628 03-08-2017, 10:38 PM
Last Post: pfeerick
  any danger from using 2 power sources at same time? dkryder 3 6,951 01-20-2017, 10:45 PM
Last Post: MarkHaysHarris777
Lightbulb A Tale of Two Power Supplies - why good is good and better is best MarkHaysHarris777 9 18,366 01-07-2017, 11:59 PM
Last Post: aegrotatio
