1024x600 resolution support
So I have found some kind of a solution. I looked at all available video modes and the clock settings they have. This way I knew what clocks are supported in the kernel. Then I chose the one that was close to desired value and constructed the modeline with cvt.
To anyone who may look for a solution, as I did, here are my final settings:
xrandr --newmode 1024x600 49.50 1024 1029 1042 1312 600 602 605 622 -hsync +vsync
xrandr --addmode HDMI-1 1024x600
xrandr --newmode 1024x576 49.50 1024 1072 1168 1312 576 579 584 600 -hsync +vsync
xrandr --addmode HDMI-1 1024x576
This only works in ayufan's build, Armbians with new mainline kernel aren't good in terms of graphics support. The reason I've made two resolutions is that though native resolution is stated to be 1024x600 and it seems to be correct, the image is not square with this resolution, it looks squashed a little. 1024x576 seems to be correct geometrically, but is little blurrier (I wonder if this panel has not square pixels), so you can try and choose the one you like more. Anyway both of this resolutions give much better image then the standard and the screen works as it supposed.
I would like to have better solution, because now if you disconnect/reconnect the display it sets random resolution and you have to set it again manually. Also console resolution is wrong still, but it may be fixed with fbset, but I didn't test it.
1024x600 resolution support - by monte - 03-14-2021, 03:49 PM
RE: 1024x600 resolution support - by monte - 03-14-2021, 11:32 PM
  Encryption support rockfun 1 2,946 06-10-2020, 08:27 AM
Last Post: rockfun
  Installing DietPie on Rock64 and set 1280x1024 resolution Dape97 2 3,831 05-26-2020, 07:20 AM
Last Post: Dape97
  mainline kernel sound support Openwrt lucize 2 4,079 05-01-2020, 05:09 PM
Last Post: PakoSt
  5.3 kernel support? csrf 5 7,115 04-18-2020, 11:34 PM
Last Post: CameronNemo
  MSI-X support for KVM? pfworks 1 3,645 06-12-2019, 03:48 AM
Last Post: RussianNeuroMancer
  Hyperion/Ambilight support? qwasy 5 7,723 03-30-2019, 04:40 PM
Last Post: antaril
  Arch Linux minimal image w/ full HDMI output support hiccupstix 1 3,655 11-01-2018, 08:33 AM
Last Post: danboid
  Most stable Linux rom and 1080p support? Nelly 2 4,098 10-08-2018, 12:30 PM
Last Post: Nelly
  Updates on Mainline Linux Support? hnaguski 0 2,478 09-11-2018, 08:16 PM
Last Post: hnaguski
  Kodi + Docker - what are the image options for Rock64 to support this? zarusz 0 2,614 05-20-2018, 01:41 AM
Last Post: zarusz
