5.3 kernel support?
what's the status on kernel developement/support for the latest 5.x kernel?
I have a rock64 (version 1?) and I'm wondering if there are still plans to support it, or if the board is more/less being "given up on" at this point...
(10-17-2019, 04:36 PM)csrf Wrote: what's the status on kernel developement/support for the latest 5.x kernel?
Working well  with arch linux arm. I'm using them headless as network appliances. I don't know if there are video issues. The network stack and USB3 performance is RADICALLY IMPROVED, compared to earlier kernels.
[root@honeypot3 ~]# cat /proc/version
Linux version 5.3.6-1-ARCH (builduser@leming) (gcc version 8.3.0 (GCC)) #1 SMP Sat Oct 12 17:02:44 UTC 2019
thanks for the info, however, I'm wondering when the mainline kernel will more generally be supported by other distros, as I prefer to go with a Debian-based system. Is this an issue where rockchip hasn't progressed in releasing an updated kernel???
(10-18-2019, 02:17 PM)csrf Wrote: thanks for the info, however, I'm wondering when the mainline kernel will more generally be supported by other distros, as I prefer to go with a Debian-based system.  Is this an issue where rockchip hasn't progressed in releasing an updated kernel???
No idea about that.
+1 bump for Debian based distro support.
Confirm had good success with arch earlier.
Please share your dotconfig, or any patches to the kernel you needed to make!
  How to boot an older, working kernel bits 0 3,048 11-01-2024, 04:43 PM
Last Post: bits
  Linux 5.15 Kernel - openSuse mark1250 0 3,030 12-02-2021, 04:36 PM
Last Post: mark1250
  Security Patches for the Kernel kwinz 9 14,607 10-22-2021, 05:45 AM
Last Post: kwinz
  1024x600 resolution support monte 1 6,230 03-14-2021, 11:32 PM
Last Post: monte
  Debian kernel stuck at 4.4.167 Enig123 5 10,844 12-29-2020, 12:57 PM
Last Post: kwinz
  Arch Linux Arm --> Kernel 5.8 breaks installation as365n4 12 22,240 08-31-2020, 01:41 AM
Last Post: as365n4
  Encryption support rockfun 1 5,021 06-10-2020, 08:27 AM
Last Post: rockfun
  mainline kernel sound support Openwrt lucize 2 7,531 05-01-2020, 05:09 PM
Last Post: PakoSt
  Help troubleshooting kernel panic gabrielfin 3 8,150 03-02-2020, 04:18 PM
Last Post: gabrielfin
  need a dts file to set some pins as pulldown interrupts in kernel using a DTO dkebler 0 3,663 02-05-2020, 10:58 PM
Last Post: dkebler
