Is there a RIght and Wrong MicroSD?
Don't forget to test it's capacity.
I use the Linux tool, f3write & f3write which seems to do the job. Their are MS-Windows tools as well, if you want to test there. It does not mater where you test, just test it once to verify it's capacity is what it says it is.
Arwen Evenstar
Princess of Rivendale
RE: Is there a RIght and Wrong MicroSD? - by Arwen - 03-04-2021, 11:46 AM
Question Disassembling PineBook Pro Docking Deck (due to disappeared microSD card) gritibaenz 4 4,483 04-02-2021, 06:45 PM
Last Post: tkudog
  microSD card stuck charlesnorris 7 8,106 11-19-2020, 05:11 AM
  Can't figure out where MicroSD space is kendew 4 5,852 09-23-2020, 07:25 PM
Last Post: Paulie420
  Emmc to MicroSD adapter won't fit in recessed slot of pbp sunjam 3 4,450 03-04-2020, 01:20 PM
Last Post: zaius
  Wrong resolution on external monitor vfr400racer 2 3,525 01-11-2020, 04:46 PM
Last Post: regivanx
  You toggled wrong switch - Pinebook Pro will not power on hmuller 0 2,028 11-07-2019, 01:25 PM
Last Post: hmuller
