You toggled wrong switch - Pinebook Pro will not power on
For those of you using the headphone UART cable:
If you toggle the eMMC enable/disable switch by mistake your Pinebook Pro may not power on.
To resolve this toggle the eMMC switch back towards the hinge to enable eMMC. And then press the reset button. The device should now power on.
You will now find these instructions in the wiki.
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 2 525 04-09-2024, 04:33 AM
Last Post: maxjrh
  Pinebook Pro on Debian 12 Power Issue u974615 1 328 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 270 02-17-2024, 07:06 PM
  Pinebook Pro charging issues tomekdev 1 607 01-05-2024, 08:40 PM
Last Post: tomekdev
  Replacement battery for PineBook Pro DrYak 3 1,073 11-07-2023, 10:09 AM
Last Post: DrYak
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 129,809 09-13-2023, 03:43 AM
Last Post: k3dAR
  PineBook Pro dead ottahe 9 5,979 01-18-2023, 07:41 PM
Last Post: ottahe
  Pinebook Pro malfunctioned hardware samtux 10 4,398 12-27-2022, 03:31 PM
Last Post: samtux
  PineBook Pro revision 2.2: Wishlist for the hardware issue fixes dsimic 115 135,142 11-30-2022, 04:28 PM
  Increasing the maximum power draw dsimic 15 19,524 11-21-2022, 03:36 AM
Last Post: bircoph
