PBP USB-C Docking Deck HDMI 4k upto 60fps possible?
Hi I am starting to use the USB-C deck to connect to my 4K monitor.
The description for the item on Pine store is 4k/P30 (means 30 fps?), and that's what I got when I am using it. But on the other hand the USB-C to HDMI converter I had is allow me to select 4K at 60 fps on the display setting, where the PBP deck only allow the 4k 30 fps selection.
Is it possible the HDMI cable I am using the bottlenect, there isn't any meanful lable I can tell. Happy to buy a new one if it might be the issue? But on the other hand, it might be a hardware limitation due to the deck need provide USB3 and HDMI outputs at the same time from a single USB-C connected to the PBP for input?
PBP USB-C Docking Deck HDMI 4k upto 60fps possible? - by Paull - 02-26-2021, 10:28 PM
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 4 602 Yesterday, 09:27 AM
  HDMI and PBP USB C port IMSAI8080 0 1,122 09-26-2022, 09:17 AM
Last Post: IMSAI8080
  PBP (PPP) docking deck detailed spec Rosbeefandino 6 3,262 09-14-2022, 10:59 PM
Last Post: dachalife
  PBP (PPP) docking deck : no hdmi sound Rosbeefandino 0 993 07-24-2022, 06:19 PM
Last Post: Rosbeefandino
Question PINEBOOK Pro USB-C Docking Deck issues pawzy 3 4,955 06-19-2022, 09:47 AM
  Pinebook Pro Docking Deck Seems to be DOA Inig0M0nt0ya 1 2,468 02-19-2022, 10:22 PM
Last Post: angeloweb
  Ethernet issue on USB-C Docking Deck Nongorre 2 2,628 02-19-2022, 10:18 PM
  Pinebook Pro Docking Deck Ethernet Port MickTheGeek 1 2,474 06-16-2021, 07:49 PM
Last Post: Kuawi
  Docking Deck shipping? tkudog 3 4,620 05-18-2021, 07:29 PM
Question Disassembling PineBook Pro Docking Deck (due to disappeared microSD card) gritibaenz 4 4,452 04-02-2021, 06:45 PM
Last Post: tkudog
