PBP (PPP) docking deck detailed spec
where can i find complete specification of this product?
i want it to work well with my ppp and mobian.
i 'm not a good developper but want to practice to firmware and driver development .
but first i think i need good understanding of this hardware.
for now i clarify the structure of usb tree :
usbA ports numbered from vga port to sdcar reader A1,A2,A3
linux bus 5
 -> Vialab usb2 hub 4ports Vendor=2109 ProdID=2817
    -> port1 directly connected to physical port A2
    -> port2 directly connected to physical port A1
    -> port3 ?
    -> port4 conected to Terminus hub 4 ports Vendor=1a40 ProdID=0801
        -> port1 directly connected to physical port A3
        -> port2 ?
        -> port3 ?
        -> port4 terminus hub 4p Vendor=1a40 ProdID=0801
            ->port1 directly connected to physical SDcard port
            ->port2 directly connected to physical microSD port
            ->port3 fresco logic ( it6564?) hdmi/vga convertor Vendor=1d5c ProdID=7102
                            ^seems to have a firmware is it possible to flash ?
            ->port4 CMX sound card conected to audio jack Vendor=2000 ProdID=dd00
linux bus 6
 -> vialab usb3 hub 4p
    -> port1 ?
    -> port2 ?
    -> port3 eth adapter rtl8153 0bda:8153
    -> port4 ?
how i named the ports ; from left to right facing the ports
jack, sdcard/microsdcard, usbc 2, usbc 1, usba 3, usba2, usba1, vga, hdmi, usbc pd Femal, usbc pd male.
i don't know where shoud be mentioned the sound card to send audio thrue the HDMI. is it an interface of the it6564.
maybe it required to send specific encoded sound to specific it6564 interface?
is anyone have a photo of the interior of the docking station ?
working:
microsd: ok
sdcard: ok
usba1 2 3: ok
sound work : with some bugs on mobian
ethernet: seems to work not tested but appear
bugs :
usbc 1 2: not pd, so not much power delivered. but seems to work (not relly tested)
hdmi : no sound
hdmi : process to make external screen work
                - reboot the phone disconected from dock then unlock
                - disconect the power from the dock
                - connect the phone to the dock and wait for the sreen background on the external display
            from there
            what is working : - disconect/reconect THE POWER souce from dock (reset the screen configuration)
                                          - configure the screen
            what is not working : disconect/reconnect the phone from the dock. (Need phone reboot ad process restart).
Hi, I’ve just ordered one for my PBP & if needed, I’ll post the results of testing,
Satisfied PinePhone, Pinebook Pro & PineTab2 owner; Thank you Pine64Team for your work!  Smile
(08-27-2022, 05:14 PM)dachalife Wrote: Hi, I’ve  just ordered one for my PBP & if needed, I’ll post the results of testing,
Did you recieved it and with with which device will you share ? PBP or PPP ?
It’s the dock for the PBP, but it’s not here; my order wasn’t exported from China due to some problem on their end.
I notified Pine, support confirmed the export/shipping problem and I’m waiting on a solution.
Just for information this PBP deck is also, at least for me, compatible with the PPP. i use my PPP as daily conveged mobile/fix "smartputer".
Yea, I'm using the PP one with it & have no complaints.
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 2 529 04-09-2024, 04:33 AM
Last Post: maxjrh
  PBP (PPP) docking deck : no hdmi sound Rosbeefandino 0 982 07-24-2022, 06:19 PM
Last Post: Rosbeefandino
Question PINEBOOK Pro USB-C Docking Deck issues pawzy 3 4,909 06-19-2022, 09:47 AM
  Pinebook Pro Docking Deck Seems to be DOA Inig0M0nt0ya 1 2,453 02-19-2022, 10:22 PM
Last Post: angeloweb
  Ethernet issue on USB-C Docking Deck Nongorre 2 2,604 02-19-2022, 10:18 PM
  Pinebook Pro Docking Deck Ethernet Port MickTheGeek 1 2,454 06-16-2021, 07:49 PM
Last Post: Kuawi
  Docking Deck shipping? tkudog 3 4,576 05-18-2021, 07:29 PM
Question Disassembling PineBook Pro Docking Deck (due to disappeared microSD card) gritibaenz 4 4,411 04-02-2021, 06:45 PM
Last Post: tkudog
  PBP USB-C Docking Deck HDMI 4k upto 60fps possible? Paull 2 3,492 02-27-2021, 11:35 PM
Last Post: Paull
Photo PineBook Docking Deck charging port? ColoBill 3 5,242 02-26-2021, 10:07 PM
Last Post: Paull
