No ability to cancel out of Applications in Both KDE Plasma AND Mobian
Basic Wrote:
The3DmaN Wrote:
Basic Wrote:OK I have Arch Linux on it now...can make SMS and Phone calls, AND I can swipe out of Apps.  Cool
Not sure if it made the difference, but I used Trisquel 9 ( vs. 7) with the jump drive and it uses a different version of Archive manager.
I am keeping the thread open for now...just in case...as this is not the first time I thought I had the solution...only to have a major issue.
Thanks to all, but a special thank you to The3DmaN. Big Grin
Glad to see its working for you on Arch. Arch is pretty stable (still some bugs) and in my opinion the best working distro right now. It is also updated quite frequently as well. Just type the below into the terminal to fetch and apply updates:
sudo pacman -Syyu
I will try that in the near future, the only thing that is is reporting issues is Lollypop... Mucho Gracias Amigo
Well ARCH froze up on me. Could not get past the log in screen.
I did not update as the phone was working fine until 2 days ago, phone was just fine in the day, something went wonky at night. Wifi dip switch was in the "off" position...as all I need is a phone for calls and SMS. I did change the root password early on.
I also am having issues with the pine support site in updating this issue, cant log in with my current password, and not able to reset at this time.  Confused
I am on the fence as to what distro/ OS to try next, or re-install ARCH.
RE: No ability to cancel out of Applications in Both KDE Plasma AND Mobian - by Basic - 03-02-2021, 05:20 AM
  Can't get Mobian on PinePhone to recognise USB-C docking bar duncan_bayne 9 6,999 12-04-2023, 02:14 AM
Last Post: Peter Gamma
  Mobian PIN changed after update! Mwo87 21 17,833 12-02-2023, 11:53 PM
Last Post: Karrenbrady
  pinephone texting ability goes in an out jyoung 0 659 08-05-2023, 10:15 PM
Last Post: jyoung
  Problems updating KDE Plasma Mobile OS IMSAI8080 6 3,387 06-30-2023, 11:39 PM
Last Post: ionmich
  Cellular Data, Mobian - "No WWAN Adapter Found" justneedsomedatathanks 3 4,257 05-25-2023, 09:03 PM
Last Post: justneedsomedatathanks
  Buyer beware: Pine64 is not checking their sales email, won't alter or cancel orders 3x5co 5 4,064 01-10-2023, 06:30 PM
Last Post: 3x5co
  No sound after Mobian upgrade arbocenc 1 772 11-28-2022, 11:02 AM
Last Post: arbocenc
Exclamation No wIfI after Mobian update crakabeats 3 2,134 11-03-2022, 04:16 AM
Last Post: wifinoworkie
  pinephone-support package not upgradable on Mobian fhireman 4 2,385 09-24-2022, 08:01 AM
Last Post: dante404
  plasma-dialer doesn't call Ant 7 4,002 04-08-2022, 03:09 PM
Last Post: israel
