Kali Linux password fail
(02-08-2021, 06:35 PM)barray Wrote: You could login as root and force a change password that way. Your other option would be to boot another Linux distro and edit the passwords file under a root account.
Btw, Kali Linux is by design insecure, you really shouldn't use it as a daily driver.
I couldn't login as root because version 2020.1 does not have root account - https://www.linuxuprising.com/2020/01/ka...-root.html
" In an article posted on the Kali blog, it's explained that over the years, more and more users have started to use Kali as their daily driver. With this usage increasing over time, "there is the obvious conclusion that default root user is no longer necessary and Kali will be better off moving to a more traditional security model." "
Kali Linux password fail - by Wawe - 02-08-2021, 02:03 PM
RE: Kali Linux password fail - by barray - 02-08-2021, 06:35 PM
RE: Kali Linux password fail - by Wawe - 02-09-2021, 09:06 AM
RE: Kali Linux password fail - by barray - 02-09-2021, 01:38 PM
RE: Kali Linux password fail - by wdt - 02-09-2021, 11:26 AM
RE: Kali Linux password fail - by Wawe - 03-23-2021, 11:09 AM
  Attempting to install Void Linux, boots into a black screen 9a3eedi 0 347 02-18-2024, 08:54 AM
Last Post: 9a3eedi
  Nethunter default password failed lamlarryyyy 0 355 11-23-2023, 02:48 AM
Last Post: lamlarryyyy
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,492 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
  Kali Linux for Pinebook Pro - stuck on the login screen owaspfap 0 669 07-13-2023, 05:21 PM
Last Post: owaspfap
  Kali Linux for Pinebook Pro Luke 100 160,055 05-03-2023, 06:10 AM
Last Post: dachalife
  DiY - Installing Void Linux ARM On The Pinebook Pro vincele 1 1,206 11-28-2022, 05:03 PM
  Arch Linux ARM root filesystem SKiljan 24 20,910 09-24-2022, 03:11 AM
Last Post: alexandre
Information Install Void Linux with near-full-disk encryption dumetrulo 3 3,103 09-05-2022, 12:00 PM
Last Post: petersen77
  Help with Kali Linux wifi not working but works with Manjaro PineSupporter 2 2,388 08-25-2022, 02:15 PM
Last Post: Niko
  Manjaro Gnome 22.06 pamac update fail/soft-bricked-OS u974615 5 2,388 08-21-2022, 12:00 PM
Last Post: u974615
