(potential) work-around for Playstore authentication issue
(06-26-2016, 09:57 PM)CypherColt Wrote: My solution was to uncheck the Sync for apps and check it again, without even exiting the Google Play app. Worked right away for me.
Hope this helps!
Edit: (to specify)
I went into Settings, Accounts, Google, my email, i disabled App Data sync, and then enabled it again.
Im sure it will help someone, thanks Smile
RE: (potential) work-around for Playstore authentication issue - by Luke - 06-27-2016, 06:49 AM
  USB GPS dongles that work with Android on Pine64+ ? trondkj 2 4,479 11-16-2017, 02:14 PM
Last Post: Skivholme
  Playstore Selections Limited in 7.1 TV CharlieB 2 3,545 10-19-2017, 12:24 PM
Last Post: Luke
  Does snapchat work on pine64 with android? user875545 1 4,240 08-29-2017, 12:05 AM
  VPN issue on Pine64 pinea64.edison 4 6,533 06-27-2017, 12:25 PM
Last Post: milkaca
  No Intenet Access Need Help Diagnosing Underlying Issue Bob123456789 10 11,267 06-02-2017, 01:32 PM
Last Post: Bob123456789
  anyone make pine64 lcd hdmi work simultaneously bokeer 4 7,040 12-11-2016, 05:57 PM
Last Post: Luke
  ethernet does not work with Android 5.1.1 Image Release 20160711 (Known Problem) mathiraj 18 24,155 10-29-2016, 04:31 AM
Last Post: joe
  pine64 a piece of work water 4 5,999 10-28-2016, 07:41 AM
Last Post: jkmooney
  buring image with 'dd' on linux doesn't work (Solved) mathiraj 2 5,654 10-17-2016, 11:42 AM
Last Post: mathiraj
Sad Airmouse doesn't work on any Android ameth 0 2,630 09-11-2016, 06:29 AM
Last Post: ameth
