USB GPS dongles that work with Android on Pine64+ ?
Hi
Have anybody got any usb gps dongles to work with android on Pine64+? I would love to have positioning to work on my Pine64 with touchscreen. If anybody have tried it and got it to work, it would be nice to know Smile
Trond Kjetil
This USB GPS library works at Android.
.zip   Android_GPS_lib64.zip (Size: 13.29 KB / Downloads: 316)
(09-25-2017, 05:09 AM)trondkj Wrote: Hi
Trond Kjetil
I got a bu-353 GPS working with an app and mock position.
The gps did not show up as an tty device, so i could not get the Android_GPS_lib64 working.. Smile
I used this lib to read the serial.
https://github.com/felHR85/UsbSerial
Then this NMEA parser to parse the data from serial to something readable:
https://gist.github.com/javisantana/1326141
In android manifest the following permissions should be set:
<uses-permission android:name="android.permission.ACCESS_FINE_LOCATION" />
<uses-permission android:name="android.permission.ACCESS_COARSE_LOCATION" />
<uses-permission android:name="android.permission.ACCESS_MOCK_LOCATION" />
I used Androids LocationManager to make a mock position.
On the device i had to enable developer mode (Settings -> About tablet, click 7 times on "Build number"), and then allow my app to set mock position in settings -> developer options.
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 389,631 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 29,795 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 16,877 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 7,005 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 7,080 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 5,633 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 3,354 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 259,287 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 3,558 02-26-2019, 11:58 AM
Last Post: Twistedx
  Android 7.1 (PINE A64(+)) pineadmin 59 105,462 02-10-2019, 07:44 PM
Last Post: mmmarcus
