Security Patches for the Kernel
(01-06-2021, 11:33 PM)ryo Wrote: The general thing about SSH is, it's safe if you're not making it too easy.
Have a good password and don't login on public hotspots.
Disable root login, and create a new user which can use "sudo su" instead.
Also, you can disable password based logins, and require a valid SSH keys instead, and additionally only allow access from specific IP addresses, which is what we do at the company I'm working for.
This is what all IT companies are doing where I used to work too.
That's why I opted for Armbian. Regular updates etc. Not for everyone I know but well supported.
Security Patches for the Kernel - by kwinz - 12-28-2020, 02:55 PM
RE: Security Patches for the Kernel - by kwinz - 01-06-2021, 06:03 PM
RE: Security Patches for the Kernel - by ryo - 01-06-2021, 11:33 PM
RE: Security Patches for the Kernel - by Rocklobster - 01-07-2021, 10:27 PM
RE: Security Patches for the Kernel - by ryo - 01-07-2021, 10:33 PM
RE: Security Patches for the Kernel - by kwinz - 01-08-2021, 01:39 AM
RE: Security Patches for the Kernel - by kuleszdl - 01-15-2021, 07:37 PM
RE: Security Patches for the Kernel - by DusXMT - 01-16-2021, 12:37 PM
RE: Security Patches for the Kernel - by kuleszdl - 01-16-2021, 05:34 PM
RE: Security Patches for the Kernel - by kwinz - 10-22-2021, 05:45 AM
  Linux 5.15 Kernel - openSuse mark1250 0 1,306 12-02-2021, 04:36 PM
Last Post: mark1250
  Debian kernel stuck at 4.4.167 Enig123 5 5,707 12-29-2020, 12:57 PM
Last Post: kwinz
  Arch Linux Arm --> Kernel 5.8 breaks installation as365n4 12 12,437 08-31-2020, 01:41 AM
Last Post: as365n4
  mainline kernel sound support Openwrt lucize 2 4,101 05-01-2020, 05:09 PM
Last Post: PakoSt
  5.3 kernel support? csrf 5 7,164 04-18-2020, 11:34 PM
Last Post: CameronNemo
  Help troubleshooting kernel panic gabrielfin 3 4,686 03-02-2020, 04:18 PM
Last Post: gabrielfin
  need a dts file to set some pins as pulldown interrupts in kernel using a DTO dkebler 0 2,036 02-05-2020, 10:58 PM
Last Post: dkebler
  Any advantages to using the mainline kernel dkebler 0 2,139 11-16-2019, 12:17 PM
Last Post: dkebler
  Does anybody run the mainline kernel? CameronNemo 3 4,694 09-09-2019, 07:56 PM
  ROCK64 Kernel compilation problem cao 0 2,491 01-21-2019, 01:21 AM
Last Post: cao
