Fix your Pinebook Pro speaker connection
(07-07-2021, 11:57 PM)dsimic Wrote: While having the back cover of my first-batch ISO PineBook Pro removed, I also wanted to check the speaker connector and possibly correct the wiring.  I can confirm that the order of the wires in the connector is messed up, at least in my particular PineBook Pro.  This is also visible in the attached pictures, which all show the original, unmodified state of the speaker connector wiring.  The correct wiring is visible on page 17 of the PineBook Pro schematic.
I do wholeheartedly agree with @KC9UDX that fixing such a wiring mistake in software is bad practice.  It's really bad practice.  However, the speaker wires and the connector are so tiny and delicate that I gave up on trying to pull the wires out of the connector.  I couldn't see (almost quite literally Smile) how the wires could be pulled out of the connector without basically destroying the pins inside the connector, or destroying the wires itself.
As a note, I've been recently working on a Linux kernel patch that eliminates the crackling and popping noises, and I've expanded that patch to implement the switching between the speakers and the headphones, eliminating the need to (ab)use the acpid and to have a userspace helper script that performs the switching.  I'll also try to incorporate "normal", "l-invert", "r-invert" and "l+r-invert" as the settings available through my kernel patch, which should be usable beyond the PineBook Pro, because messing up the polarity of audio channels seems to be a rather common mistake.
Well if you have a soldering iron you can always cut the wires and reconnect them black<->red. Put some heatshrink tube over it and that should work. It's not a "good" solution but certainly easier than rewiring the connector.
RE: Fix your Pinebook Pro speaker connection - by Kaythe - 07-08-2021, 12:51 AM
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 4 724 05-06-2024, 09:27 AM
  Pinebook Pro on Debian 12 Power Issue u974615 1 376 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 322 02-17-2024, 07:06 PM
  Pinebook Pro charging issues tomekdev 1 661 01-05-2024, 08:40 PM
Last Post: tomekdev
  Replacement battery for PineBook Pro DrYak 3 1,163 11-07-2023, 10:09 AM
Last Post: DrYak
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 131,574 09-13-2023, 03:43 AM
Last Post: k3dAR
  PineBook Pro dead ottahe 9 6,116 01-18-2023, 07:41 PM
Last Post: ottahe
  Pinebook Pro malfunctioned hardware samtux 10 4,556 12-27-2022, 03:31 PM
Last Post: samtux
  PineBook Pro revision 2.2: Wishlist for the hardware issue fixes dsimic 115 138,012 11-30-2022, 04:28 PM
  Decent Pinebook Pro barrel PSU / Charger petaramesh 3 1,962 10-21-2022, 07:57 AM
Last Post: dachalife
