Troubleshooting RockPro64 + Roshambo case SSD problems
I recently purchased a RockPro64 & Roshambo case, and I installed Batocera Linux on it and enabled the case, everything seems to work but the RoshamboPro kit seems to have a problem when inserting the SSD on the board.
When I insert the SSD into the board, the unit behaves erratically, some of the behaviors I have witnessed include USB panel in front of the unit stops responding, fan stops, SSD is recognized momentarily, top buttons (Power/Reset) stop working and sometimes the LED 706 inside the unit will blink. After removing the SSD, the system behaves normally.
I have rules out a problem with the SSD (It works fine when connecting to other machine) or with the RockPro64 USB3 (when I connect the SSD directly outside the case, it works), but I don't know if it is a problem with the cable connecting the RockPro64 to the board or the Roshambo board itself.
Anyone has experienced similar issues? Any known workaround?
Troubleshooting RockPro64 + Roshambo case SSD problems - by necoc.yaotl - 11-20-2020, 01:57 PM
  Installing Wifi drive for the RockPro64 John45595 0 312 02-10-2024, 11:32 PM
Last Post: John45595
  Roshambo 2023 angeloweb 2 1,370 12-19-2023, 03:07 AM
Last Post: Maxpako
Wink You don't sell case and fan for "ROCKPro64 4GB Single Board Computer"? Clea 1 758 09-17-2023, 12:00 AM
  Want to check maximum toggle speed in Rockpro64 board. kundanjha 0 683 08-14-2023, 07:55 AM
Last Post: kundanjha
  Unable to boot Armbian on new RockPro64 mooseball 5 4,261 07-14-2023, 08:59 AM
Last Post: rockjonn
  Hardware fix for software sound problem on Rockpro64 Ricks Rockpro 0 893 04-06-2023, 03:59 PM
Last Post: Ricks Rockpro
  No sound on Rockpro64 with OpenWrt Patrice 1 1,329 04-06-2023, 02:46 PM
  Cant get rockpro64 working brasilikum 3 1,827 03-19-2023, 06:22 AM
Last Post: runyor
  RockPro64 Stopped working WarpLover 5 2,656 02-06-2023, 10:10 AM
Last Post: diizzy
Lightbulb ROCKPro64 + SSD case model for 3D print Spater 0 1,022 01-27-2023, 07:43 PM
Last Post: Spater
