FydeOS for You - Pinebook Pro
(11-23-2020, 10:34 PM)lrussell887 Wrote: I just flashed the image to a microSD with Etcher and tried to boot it on my Pinebook Pro. The screen backlight turns on and the power light turns green but nothing ever appears on the screen. If I let it sit long enough a startup sound plays, so I would guess that it's booting. I have the ANSI model if that makes a difference, and Manjaro is installed to the eMMC. Doing a hard shutdown and starting up again doesn't make a difference, the screen stays black. Trying to switch TTYs, Ctrl+Alt+F2 causes the backlight to flicker but still nothing shows on screen.
 I can report the same behavior. I downloaded the image. Etcher is used to flash the image which completes without error. The SD card appears to boot, the status light turns from red to green after some time has passed a startup sound is heard and the screen seems faintly lit. However nothing happens beyond that. Ctrl+Alt+F2 cause the back light to flicker.
I have left the machine sit for an hour while doing other things, but it never boots to a screen.
bill
FydeOS for You - Pinebook Pro - by also1412 - 11-17-2020, 08:56 PM
RE: FydeOS for You - Pinebook Pro - by Wizzard - 11-18-2020, 04:54 AM
RE: FydeOS for You - Pinebook Pro - by tophneal - 11-18-2020, 09:30 AM
RE: FydeOS for You - Pinebook Pro - by Wizzard - 11-18-2020, 09:34 AM
RE: FydeOS for You - Pinebook Pro - by clover - 11-18-2020, 10:05 AM
RE: FydeOS for You - Pinebook Pro - by tophneal - 11-18-2020, 03:01 PM
RE: FydeOS for You - Pinebook Pro - by also1412 - 11-18-2020, 10:24 PM
RE: FydeOS for You - Pinebook Pro - by tophneal - 11-19-2020, 08:12 AM
RE: FydeOS for You - Pinebook Pro - by also1412 - 11-19-2020, 08:45 AM
RE: FydeOS for You - Pinebook Pro - by clover - 11-19-2020, 02:21 PM
RE: FydeOS for You - Pinebook Pro - by also1412 - 11-19-2020, 09:26 PM
RE: FydeOS for You - Pinebook Pro - by wove - 11-24-2020, 07:17 AM
RE: FydeOS for You - Pinebook Pro - by tophneal - 11-24-2020, 09:41 AM
RE: FydeOS for You - Pinebook Pro - by wove - 11-24-2020, 12:00 PM
RE: FydeOS for You - Pinebook Pro - by cefre00 - 01-06-2021, 04:52 AM
RE: FydeOS for You - Pinebook Pro - by tophneal - 01-07-2021, 08:15 AM
RE: FydeOS for You - Pinebook Pro - by cefre00 - 01-08-2021, 02:47 AM
RE: FydeOS for You - Pinebook Pro - by tophneal - 01-12-2021, 07:51 AM
RE: FydeOS for You - Pinebook Pro - by cefre00 - 01-12-2021, 09:52 AM
RE: FydeOS for You - Pinebook Pro - by tophneal - 01-12-2021, 10:35 AM
RE: FydeOS for You - Pinebook Pro - by cefre00 - 01-12-2021, 06:54 PM
RE: FydeOS for You - Pinebook Pro - by cefre00 - 03-06-2021, 02:27 AM
FydeOS for You - Pinebook Pro - by tophneal - 01-12-2021, 06:55 PM
RE: FydeOS for You - Pinebook Pro - by cefre00 - 01-19-2021, 05:26 AM
RE: FydeOS for You - Pinebook Pro - by tophneal - 01-19-2021, 07:57 AM
RE: FydeOS for You - Pinebook Pro - by also1412 - 01-19-2021, 09:09 AM
RE: FydeOS for You - Pinebook Pro - by tophneal - 01-19-2021, 12:33 PM
RE: FydeOS for You - Pinebook Pro - by also1412 - 01-19-2021, 07:10 AM
RE: FydeOS for You - Pinebook Pro - by cefre00 - 01-19-2021, 09:49 AM
RE: FydeOS for You - Pinebook Pro - by also1412 - 01-19-2021, 09:53 AM
RE: FydeOS for You - Pinebook Pro - by cefre00 - 01-19-2021, 11:17 AM
RE: FydeOS for You - Pinebook Pro - by Wizzard - 01-20-2021, 07:17 AM
RE: FydeOS for You - Pinebook Pro - by tophneal - 01-20-2021, 11:16 AM
RE: FydeOS for You - Pinebook Pro - by Wizzard - 01-20-2021, 12:26 PM
RE: FydeOS for You - Pinebook Pro - by tophneal - 01-20-2021, 05:03 PM
RE: FydeOS for You - Pinebook Pro - by cefre00 - 01-20-2021, 04:37 PM
RE: FydeOS for You - Pinebook Pro - by cefre00 - 01-26-2021, 11:24 AM
RE: FydeOS for You - Pinebook Pro - by Wizzard - 01-21-2021, 12:01 AM
RE: FydeOS for You - Pinebook Pro - by also1412 - 02-23-2021, 03:02 AM
RE: FydeOS for You - Pinebook Pro - by ImmyChan - 03-25-2021, 12:23 PM
RE: FydeOS for You - Pinebook Pro - by Mangled - 11-14-2021, 03:36 PM
RE: FydeOS for You - Pinebook Pro - by Mangled - 01-09-2022, 03:31 PM
  Which OS can I actually run a 1080p pinebook non-pro? Scott104 1 2,750 10-09-2021, 02:47 PM
Last Post: TRS-80
Question FydeOS privacy policy? TDC_PBP 1 2,916 09-07-2021, 06:14 AM
Last Post: ImmyChan
  Black screen on both FydeOS as Chromium from github QuinTeknoLife 0 3,520 04-15-2021, 11:44 AM
Last Post: QuinTeknoLife
  CrOS boot from sd, now pinebook doesn't boot anymore qdoy55d9wkn8zw 7 11,050 06-22-2020, 06:23 AM
Question Does the Pinebook Pro support chromium developer mode? TDC_PBP 3 6,706 12-07-2019, 02:33 PM
Last Post: TDC_PBP
