Does the Pinebook Pro support chromium developer mode?
Question
Out of curiosity, I have tried putting the Pinebook Pro into developer mode via holding esc and F3 during boot, but it seems not to "see" that I am holding the keys down, booting to the login screen like normal. Is chromium developer mode not supported on the Pinebook Pro? I have Chromium installed on my emmc via Wizzard's AWESOME Dual booting chromium and linux tutorial.
(11-28-2019, 12:42 PM)TDC_PBP Wrote: Out of curiosity, I have tried putting the Pinebook Pro into developer mode via holding esc and F3 during boot, but it seems not to "see" that I am holding the keys down, booting to the login screen like normal. Is chromium developer mode not supported on the Pinebook Pro? I have Chromium installed on my emmc via Wizzard's AWESOME Dual booting chromium and linux tutorial.
I don't think this has been supported.
I think tllim is correct, but from what I've noticed reading guides and mucking about within my install, several features of the Developer Mode are still available within the install. Many seem to even be available within the base image. For example, Crouton requires use of Developer Mode, but I've gotten it to mostly work (no X/xiwi) without having to do anything special. ayufan would be the one to know, though. It could be like some Chromebooks, and require use of the Recovery button inside the case.
Ok, Thanks! What specifically does the recovery button do? I don't really see much about it on the wiki...
  FydeOS for You - Pinebook Pro also1412 52 146,091 12-19-2022, 07:42 PM
Last Post: wangyukunshan
  Which OS can I actually run a 1080p pinebook non-pro? Scott104 1 6,876 10-09-2021, 02:47 PM
Last Post: TRS-80
  Black screen on both FydeOS as Chromium from github QuinTeknoLife 0 7,223 04-15-2021, 11:44 AM
Last Post: QuinTeknoLife
  Looking to commission a new Chromium build (COMMUNITY BOUNTY) tophneal 86 176,828 11-06-2020, 09:25 AM
  CrOS boot from sd, now pinebook doesn't boot anymore qdoy55d9wkn8zw 7 18,915 06-22-2020, 06:23 AM
  Chromium OS 78? obyknovenius 2 9,375 02-04-2020, 02:11 PM
Last Post: brent.thierens
  Possible to use different uboot with Chromium? tophneal 1 6,691 11-04-2019, 08:38 AM
