Which OS can I actually run a 1080p pinebook non-pro?
I have tried a bunch of different images with various kernels, but in all cases performance is unusable. I'd like to use this device for [i]something[/i], but it needs to be reasonably good at it. I had issues with: some images black screening because they were intended for the low-res screen, some images not working when transferring them to emmc, GUI performance in general sucking, hardware support being incomplete and even non-GUI applications being slow. Kali worked, but it was just too slow to do anything. I'm not even expecting web browsing, at least a usable desktop. Is this even possible?
What are you running and what is the least sucky option that at least works?
[Image: renderTimingPixel.png]
Did you try Armbian?
Cheers,
TRS-80
Protocols, not Platforms
  FydeOS for You - Pinebook Pro also1412 52 135,085 12-19-2022, 07:42 PM
Last Post: wangyukunshan
  CrOS boot from sd, now pinebook doesn't boot anymore qdoy55d9wkn8zw 7 17,371 06-22-2020, 06:23 AM
Question Does the Pinebook Pro support chromium developer mode? TDC_PBP 3 10,213 12-07-2019, 02:33 PM
Last Post: TDC_PBP
