Black screen on both FydeOS as Chromium from github
Hey,
I've been trying to get Chromium OS to start from sd, but both FydeOS as Chromium R77 are giving me a black screen and a (single) chime sound on boot...
Edit: I have resolved the issue. If anyone else is running into these not booting issues, install mrfixits' u-boot (using an SD-card with any working linux, flip the eMMC/SD switch to SD, press the power button and after 2 seconds flip the switch back to eMMC and you should be booting off the SD-card while still being able to write to the eMMC)
  FydeOS for You - Pinebook Pro also1412 52 134,805 12-19-2022, 07:42 PM
Last Post: wangyukunshan
Question FydeOS privacy policy? TDC_PBP 1 6,376 09-07-2021, 06:14 AM
Last Post: ImmyChan
  Looking to commission a new Chromium build (COMMUNITY BOUNTY) tophneal 86 163,008 11-06-2020, 09:25 AM
  Chromium OS 78? obyknovenius 2 8,575 02-04-2020, 02:11 PM
Last Post: brent.thierens
Question Does the Pinebook Pro support chromium developer mode? TDC_PBP 3 10,200 12-07-2019, 02:33 PM
Last Post: TDC_PBP
  Possible to use different uboot with Chromium? tophneal 1 6,019 11-04-2019, 08:38 AM
