Main Board Swap: Camera connector problems
(11-12-2020, 10:02 PM)tyha Wrote: Hoping there is someone that can shed some light on these connectors for the cameras. I popped off the hinge (on a braveheart edition) to remove the ribbon connector, but I'm having problems getting it to clamp back down on the new main board revision.
In the video with Martign Braam installing a new board, he conveniently has the cameras preinstalled yet this is the part that I'm having the only problems with, and of course that is the part the factory did for him (probably because it's a pain).
They appear to be just hinged and not the ones you have to flip then slide it in to lock but I'm putting a lot of force and it has started to flake off some of the plastic so I'm afraid of going further.
Video for reference: https://www.youtube.com/watch?v=5GbMoZ_zuZs
EDIT:
Looks like the camera connector will not have an audible click when it is pivoted down. After pushing the ribbon all the way in (make sure to do this) with the clamp up, begin to push the clamp part down and it will cause a "ratchet" motion when you reach about 45 degrees with the clamp. After which it will continue to push the ribbon down without snapping into place and it will impart pressure down to keep the ribbon connected... at least that is what I'm guessing as i haven't been able to get mine to turn on. My board might be DOA. I'm not getting the screen on yet with the factory image still on there or the jumpdrive image loaded onto an SD card. Anyone else have a dead replacement board?
As far as the camera goes, I had no trouble getting it connected and clamped properly, so you're on the right track.
There is no OS on the emmc to boot from, and since it's a 3GB/32GB mainboard, you'll probably need to update your JumpDrive to version 0.6 to support this mainboard.
RE: Main Board Swap: Camera connector problems - by pajux - 11-19-2020, 06:25 PM
  Pine phone main board part Generaltuxenburg 1 1,070 07-31-2023, 07:50 PM
  USB-C connector Overheated and melted nickbenjones 2 1,347 05-26-2023, 06:16 PM
  USB C side board out of stock gab 3 1,872 12-29-2022, 11:42 AM
Last Post: fxc
  What Adhesive to buy for daughter board? LogosCoder 1 1,037 11-28-2022, 05:07 PM
  PostmarketOS Camera and ffmeg rafiki88 1 1,512 03-19-2022, 10:09 AM
Last Post: vap0rtranz
  Would another camera work in the PP? nelstomlinson 2 2,233 11-11-2021, 06:25 PM
Last Post: nelstomlinson
Sad Have I got a broken camera module? AKD251 2 2,266 11-07-2021, 11:12 AM
Last Post: beta-user
  GPS Antenna - external connector? GregH 14 11,668 09-09-2021, 09:24 AM
Last Post: HobanWashburn
  camera firmware problems kqlnut 25 21,677 09-02-2021, 07:49 PM
  Fragile SIM card connector hakkou 1 1,825 08-25-2021, 07:44 AM
Last Post: wibble
