PostmarketOS Camera and ffmeg
I'm looking a way to capture picture from rear camera with ffmpeg, I have tried multiple ways to configure camera with media-ctl with no luck Sad
below output from media-ctl -d /dev/media1 --print-topology
Media device information
driver          sun6i-csi
model           Allwinner Video Capture Device
serial
bus info        platform:1cb0000.csi
hw revision     0x0
driver version  5.15.13
Device topology
- entity 1: sun6i-csi (1 pad, 2 links)
            type Node subtype V4L flags 0
            device node name /dev/video2
        pad0: Sink
                <- "ov5640 4-004c":0 [ENABLED]
                <- "gc2145 4-003c":0 []
- entity 5: ov5640 4-004c (1 pad, 1 link)
            type V4L2 subdev subtype Sensor flags 0
            device node name /dev/v4l-subdev0
        pad0: Source
                [fmt:SBGGR8_1X8/1280x720@1/30 colorspace:srgb xfer:srgb ycbcr:601 quantization:full-range]
                -> "sun6i-csi":0 [ENABLED]
- entity 7: gc2145 4-003c (1 pad, 1 link)
            device node name /dev/v4l-subdev1
        pad0: Source
                [fmt:SBGGR8_1X8/1280x960@1/60 field:none colorspace:raw]
                -> "sun6i-csi":0 []
and when I trying to execute ffmpeg -s 1280x720 -f video4linux2 -i /dev/video2 -vframes 1 selfie.jpg got in results error
ffmpeg version 4.4.1 Copyright (c) 2000-2021 the FFmpeg developers
  built with gcc 10.3.1 (Alpine 10.3.1_git20211027) 20211027
  configuration: --prefix=/usr --enable-avresample --enable-avfilter --enable-gnutls --enable-gpl --enable-libass --enable-libmp3lame --enable-libvorbis --enable-libvpx --enable-libxvid --enable-libx264 --enable-libx265 --enable-libtheora --enable-libv4l2 --enable-libdav1d --enable-postproc --enable-pic --enable-pthreads --enable-shared --enable-libxcb --enable-libsrt --enable-libssh --enable-libvidstab --disable-stripping --disable-static --disable-librtmp --enable-libaom --enable-libopus --enable-libsoxr --enable-libwebp --enable-vaapi --enable-vdpau --enable-vulkan --disable-debug
  libavutil      56. 70.100 / 56. 70.100
  libavcodec     58.134.100 / 58.134.100
  libavformat    58. 76.100 / 58. 76.100
  libavdevice    58. 13.100 / 58. 13.100
  libavfilter     7.110.100 /  7.110.100
  libavresample   4.  0.  0 /  4.  0.  0
  libswscale      5.  9.100 /  5.  9.100
  libswresample   3.  9.100 /  3.  9.100
  libpostproc    55.  9.100 / 55.  9.100
[video4linux2,v4l2 @ 0xffff9b534670] ioctl(VIDIOC_STREAMON): Broken pipe
/dev/video2: Broken pipe
I'm using main version of postmarketos
any ideas?
The megapixels contributor does occasionally mention ffmpeg in his blogs, so maybe looking there or filing an issue on the tracker could point you in the right direction.
Blog: https://blog.brixit.nl/tag/phones/
Tracker: https://gitlab.com/postmarketOS/megapixels
PPv1.2a running PMOS ... almost a daily driver!
  Would another camera work in the PP? nelstomlinson 2 2,227 11-11-2021, 06:25 PM
Last Post: nelstomlinson
Sad Have I got a broken camera module? AKD251 2 2,263 11-07-2021, 11:12 AM
Last Post: beta-user
  camera firmware problems kqlnut 25 21,644 09-02-2021, 07:49 PM
  camera + megaixel and strange behavior streak 0 1,689 06-02-2021, 06:45 AM
Last Post: streak
  Pinephone camera thread ryo 8 8,351 05-29-2021, 03:21 AM
Last Post: ryo
  Camera clicking sound unsatisfactory212 2 2,822 05-07-2021, 02:57 PM
Last Post: megous
  Main Board Swap: Camera connector problems tyha 5 4,721 11-19-2020, 06:25 PM
Last Post: pajux
  New PinePhone PostmarketOS CE -- No second display output audidiablo 3 4,412 09-22-2020, 05:11 AM
Last Post: Arehandoro
  Camera with stange colors zykran 0 1,577 09-18-2020, 10:05 AM
Last Post: zykran
  camera question xinyiman 3 4,499 08-31-2020, 05:50 AM
Last Post: Veraendert
