USB-C connector Overheated and melted
Hello, Postmarket os 22, pinephone daily driver now for over a year now. Plugged in my phone, while the phone was running, this morning to a USB-A to USB-C charge cable and the usb connector started melting down. Melted the back cover, the battery is ok, but the cable and usb-c side board is toast. The cable and power brick are both anker brand. Voltage and ripple on power brick seems more than reasonable, so I am ruling that out. Is this a common failure? Any idea on cause? I have never had anything like this happen before with any phone. Any guidance would be great
Cheers!
[Image: BPvRnyc]
[Image: BPvRnyc]
Similar report: https://forum.pine64.org/showthread.php?tid=14712
This can happen if the pins aren't making a good connection. (Not speaking about the Pinephone in particular, but USB charging in general).
:wq
[ SRA accepts you ]
  my pinephone melted norayr 6 824 04-04-2024, 07:22 PM
  GPS Antenna - external connector? GregH 14 11,666 09-09-2021, 09:24 AM
Last Post: HobanWashburn
  Fragile SIM card connector hakkou 1 1,824 08-25-2021, 07:44 AM
Last Post: wibble
  USB C connector loose? bceverly 3 2,980 08-10-2021, 09:44 AM
Last Post: c3l@
  Micro-USB 3.0 connector for the PinePhone? Peter Gamma 1 2,154 03-10-2021, 10:11 AM
Last Post: wibble
  broken connector-pin for the accu alwi 2 2,809 02-23-2021, 06:28 AM
Last Post: scholbert
  Main Board Swap: Camera connector problems tyha 5 4,721 11-19-2020, 06:25 PM
Last Post: pajux
  Wobbly USB-C connector? pregier 5 6,093 10-16-2020, 10:22 AM
Last Post: wibble
Bug USB Type-C connector overmold conflicts with the back cover ngkz 1 2,886 05-10-2020, 12:19 AM
