USB Type-C connector overmold conflicts with the back cover
Bug
I found that the plug overmold conflicts with the back cover when using the cable with a short plug (6.6mm). It charges the phone, but the retention mechanism is loose and the cable falls out when it swings.
According to Universal Serial Bus Type-C Cable and Connector Specification Release 2.0 page 46, the minimum length of the type-c plug is 6.51mm, so PinePhone should accept this cable.
FYI the Type-C specification recommends >=0.05mm clearance between the exterior surface of the product and plug overmold.
(05-09-2020, 06:26 PM)ngkz Wrote: I found that the plug overmold conflicts with the back cover when using the cable with a short plug (6.6mm). It charges the phone, but the retention mechanism is loose and the cable falls out when it swings.
Thanks, already ask product team looking into your suggestion.
Question Alternative Designs or Materials for the Back Cover? BMayes 2 569 12-18-2023, 11:19 AM
Last Post: BMayes
  Replacement screen disconnects after back frame is screwed on robthebold 4 1,344 10-12-2023, 01:03 PM
Last Post: robthebold
  USB-C connector Overheated and melted nickbenjones 2 1,339 05-26-2023, 06:16 PM
  GPS Antenna - external connector? GregH 14 11,664 09-09-2021, 09:24 AM
Last Post: HobanWashburn
  Fragile SIM card connector hakkou 1 1,824 08-25-2021, 07:44 AM
Last Post: wibble
  USB C connector loose? bceverly 3 2,980 08-10-2021, 09:44 AM
Last Post: c3l@
  Back cover plastic woes mteagles1942 6 6,521 03-28-2021, 10:19 PM
Last Post: NormandC
  Back cover with UBPorts logo cracked Phillip Bell 7 6,915 03-22-2021, 12:20 PM
Last Post: mteagles1942
  Micro-USB 3.0 connector for the PinePhone? Peter Gamma 1 2,154 03-10-2021, 10:11 AM
Last Post: wibble
  broken connector-pin for the accu alwi 2 2,806 02-23-2021, 06:28 AM
Last Post: scholbert
