USB C connector loose?
Anything I plug into the USB-C connector on the phone is very easily dislodged.  I mean I barely touch the phone and it comes unplugged.  Any suggestions?  It feels like things don't plug in far enough to lock into place.  Perhaps there is a cable extender/adapter that would help?
Thanks!
(08-09-2021, 01:02 PM)bceverly Wrote: Hi,
Thanks!
Hi Bceverly,
I've also had problems with my USB-C connection. In my case the supplied cable only charges one way up... presumably this is also a symptom of a loose connection. It's workable for the time being but not ideal as if I plug it in in a hurry, or forget to check, I have a 50% chance of the phone not charging at all.
It seems to me that this component of the Pinephone could and should be physically improved.
For byte-sized tech and software tips check out my Danimations Digital Media tips channel on Youtube Big Grin
Same here. Mobian CE. I've thought from the beginning that it's another hardware design flaw.
Thanks!
I use one of these to save wear and tear on my USB-C connector  https://www.aliexpress.com/item/32849697882.html
  USB-C connector Overheated and melted nickbenjones 2 1,360 05-26-2023, 06:16 PM
  GPS Antenna - external connector? GregH 14 11,753 09-09-2021, 09:24 AM
Last Post: HobanWashburn
  Fragile SIM card connector hakkou 1 1,839 08-25-2021, 07:44 AM
Last Post: wibble
  Micro-USB 3.0 connector for the PinePhone? Peter Gamma 1 2,165 03-10-2021, 10:11 AM
Last Post: wibble
  broken connector-pin for the accu alwi 2 2,828 02-23-2021, 06:28 AM
Last Post: scholbert
  Main Board Swap: Camera connector problems tyha 5 4,740 11-19-2020, 06:25 PM
Last Post: pajux
  Wobbly USB-C connector? pregier 5 6,124 10-16-2020, 10:22 AM
Last Post: wibble
  Pin missing,loose spring in phone, audio jack not working Jantje 3 4,537 06-09-2020, 02:47 PM
Last Post: wibble
Bug USB Type-C connector overmold conflicts with the back cover ngkz 1 2,897 05-10-2020, 12:19 AM
