USB C side board out of stock
I would like to report that it has been multiple weeks (more than 3) that the USB C side board is out of stock: https://pine64.com/product/pinephone-usb-c-side-board/
Any chance to have an estimate of when it will be available again ?
It is really painful to charge the phone or use USB storage when you have to apply pressure to the end of the cable.
I do own the battery charger and a second battery but that is much much less usable (I want to keep the phone plugged when I am at my desk), and also would destroy the back cover quickly.
Also regarding "For service purpose and only sell to Pinephone owner, limit quantity to 1." => I understand the point but I would really much like to have a spare to avoid this kind of situations, so allowing 2 instead of just 1 would be great Smile
Thanks in advance,
Best regards,
Gabriel
In stock again https://pine64.com/product/pinephone-usb-c-side-board/
(09-06-2022, 01:46 PM)gab Wrote: In stock again https://pine64.com/product/pinephone-usb-c-side-board/
And it's already sold out again. Sad
Does anybody know if the USB-C-Board from the Pinephone Pro is compatible with the Pinephone?
They are NOT compatible. Just open a ticket under https://support.pine64.org, the support should have replacement parts in their back hand.
  Pine phone main board part Generaltuxenburg 1 1,054 07-31-2023, 07:50 PM
  What Adhesive to buy for daughter board? LogosCoder 1 1,030 11-28-2022, 05:07 PM
  pinephone circuit board design, conductive parts zetabeta 1 1,830 08-12-2021, 05:28 AM
Last Post: wibble
  3/32 upgrade board, Arrived Without Firmware, Troubleshooting Steps to SOLVED biketool 0 1,725 06-22-2021, 10:03 AM
  Replaced USB-C side board, touch screen goes nuts Zebulon Walton 2 3,186 04-14-2021, 09:50 AM
Last Post: israel
  PinePhone replacement board won't stop vibrating acohl 8 8,145 02-28-2021, 03:36 PM
  Updated board, still have USB C charging problem xonq 7 6,303 01-31-2021, 10:47 AM
Last Post: xonq
  Possibility of a future board revision novhack 3 3,498 01-25-2021, 04:56 AM
Last Post: y2ktibltd
Question Approximate leadtime for when the 3GB/32GB mainboard is back in stock? NormandC 2 3,104 12-15-2020, 10:29 PM
Last Post: NormandC
  Got a dead main board? rocket2nfinity 6 6,640 12-15-2020, 06:48 AM
Last Post: rocket2nfinity
