Pinebook Pro won´t boot either from eMMC or microSD
(10-24-2020, 03:23 AM)KC9UDX Wrote: It sounds like you don't want linux at all!  What you want is NetBSD!  In that case, use this image http://www.armbsd.org/arm/netbsd-9/20201...pro.img.gz
But let's get this thing booting first.  What you're describing is a blank or improperly flashed micro SD card.  It does not need to be a specific one per se, but there are reports of some that don't work.  If you can, try a different one.  I use SanDisk ones (the exact type is that recommended for my GoPro camera) and Kingston (ones that came in raspberry pi bundles) and ones that I bought from Pine64.  I don't have any that don't work, but again there are reports of ones that don't.
Having the eMMC adaptor will be helpful.  But it's not necessary.
How exactly are you flashing the SD card now?  I use NetBSD, and the method I use would work for linux too, but things will be different with other operating systems.
Hahaha, I do want Linux, but I just want to set some of the stuff up. I’ll look into NetBSD later. Thanks!
Now, the thing is I had booted from the microSD before. I ran Kali from the microSD while having the default Manjaro on the eMMC. Then I flashed Arch on the microSD and when i finished with the partitions and the setting up I rebooted and it never rebooted. It got stuck on a black screen with the led light on orange color. And It stayed like that for hours. Then I tried booting from the eMMC with manjaro which shouldn’t have been affected, however, it didn’t boot. This is why I think the problem is with U-boot.
Now, if I turn off the eMMC, and hold the power button to turn on, nothing happens. The light doesn’t even turn. It’s like the power is cut off. I don’t know if the microSD stopped working. It is a sandisk which is supposed to be recommended for booting with Linux. If I insert it on my windows to flash it, it gets flashed without problems.
Finally, to flash I use etcher and I just select the image and the microSD.
Thanks for all the help, I really appreciate it.
RE: Pinebook Pro won´t boot either from eMMC or microSD - by robieguarneros - 10-24-2020, 09:01 AM
  Pinebook Pro Initial Impressions kunger 443 594,021 04-16-2024, 07:29 PM
  looking to buy one pinebook pro (mainland China) duanduan 3 2,340 03-21-2024, 07:44 PM
Last Post: wangyukunshan
  Cellular module for Pinebook Pro Lotech 1 424 03-05-2024, 05:40 AM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 321 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Sale my ANSI PineBook Pro cuthbertdavies 0 307 02-14-2024, 09:12 PM
Last Post: cuthbertdavies
  Compiling with -j6 on the Pinebook Pro (Overheat) KC9UDX 0 242 02-14-2024, 09:01 AM
  Pinebook Pro in EU for Sale - €90 jan_vdk 2 699 02-07-2024, 02:12 AM
Last Post: 23Ro
  Pinebook Pro for sale tomekdev 2 782 02-01-2024, 11:35 AM
Last Post: tomekdev
  uboot wont boot to SD card after upgrade jbradley419 7 912 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 307 01-16-2024, 09:17 AM
Last Post: jbradley419
