NVMe-related crashes and instability, plus a solution
@simonsouth - great detective work. Thanks.
I have no such problems whatsoever but anyway it's good to know.
As to the overclock. The problem is more in voltage than CPU frequency from my experience. As I wrote in another thread mine is running super stable with 1.7/2.18 GHz but it is undervolted compared to original overclock - 1.15/1.25 V (original 1.3V).
It looks like Pinebook Pros are more prone to "silicon lottery" than other products. Great example is display enabled uboot. Where I almost had no problems with it - most people do have severe problems booting newer kernels. Why ? The only solution that comes to my mind is hardware quality differences.
BTW - nobody wants to test your PWM kernel patch Smile So probably on weekend I will do this. Although, as I said, I had minor problems with booting newer kernels.
I suspect your patch might also repair screen power management problems when using display enabled uboot. When screen goes off you just can't bring it back anymore. That's on plasma DE.
And there's also kexec problem. Screen distortions after kexec. This also might have something to do with PWM.
RE: NVMe-related crashes and instability, plus a solution - by as400 - 10-01-2020, 12:39 AM
  New Working nVME gilwood 0 321 02-12-2024, 08:46 AM
Last Post: gilwood
  NVME problems 2022 / Intel 660p 1TB Starbug 1 1,656 04-04-2023, 12:16 PM
Last Post: globaltree
Thumbs Up NVMe adapter, Great addition dachalife 2 1,914 11-28-2022, 12:56 PM
Last Post: dachalife
  NVMe drives not detected mattpenn 12 10,789 03-05-2022, 04:53 AM
Last Post: mattpenn
  NVme intall usage? tkudog 2 3,030 03-04-2022, 01:29 AM
Last Post: Tazdevl
  Anyone selling a spare NVMe adapter in Europe? tom.tomasz 1 1,929 01-03-2022, 07:57 AM
Last Post: tom.tomasz
  NVMe SSD testing methodology halogen 1 2,725 07-22-2021, 05:57 PM
Last Post: calinb
Question Battery stops charging and NVMe and other media disconnect randomly Eey0zu6O 4 4,963 07-09-2021, 08:45 PM
Last Post: moonwalkers
  nvme drive disappears after about an hour of uptime codebreaker 25 32,876 02-09-2021, 11:32 PM
Last Post: dsimic
  NVME SPI Update not booting SD Card WZ9V 5 6,569 10-18-2020, 08:36 PM
