Pinebook Pro doesn't boot most of the time unless connected via USB-serial!
>Ah, uboot.. You realize that uboot also has a dtb, obviously not correct, not finding mmc,, emmc
The very strange thing is that sometimes it does find it, especially if the USB-serial cable is plugged in. Because of that I thought that maybe it could be a power issue and plugging in the cable powers the board directly bypassing the battery. It does start without the cable sometimes though.
By the way, what is the difference between the mmc and the emmc on the pinebook? I saw in the error logs that  it was trying to locate MMC1 & MMC2 which, as I understand, are different from the eMMC.
>>Since I was trying different versions of the distro
>I assume these were booting?
They were booting from the SD, yes. I think I tried a couple, the swaywm one and mostly variations of a minimal manjaro system I was building using the manjaro-arm-installer (https://gitlab.manjaro.org/manjaro-arm/a...-installer) with and without encryption.
>Experiment time!!!!
>(with dd) save emmc mbr, first 16M of emmc , blank first 16M, restore mbr
>This then will be forced to use uboot on SD card, test various uboots, various distros
>To make double sure, save SD mbr, delete all partitions with fdisk/cfdisk (on SD)
>This then will be forced to use SD uboot and emmc distro
>If seems OK, after several boots, copy 1st 16M SD ->emmc, restore emmc mbr
The SD card also doesn't boot every time now! I just tried it and it didn't, so I'm not sure this could solve this problem.
>I prefer mrfixits uboot.
Could you explain what's the difference? I'm a newbie when it comes to u-boot, its the first time I messed with it. Do you think that with these symptoms, it could be a bootloader issue?
Thanks!
RE: Pinebook Pro doesn't boot most of the time unless connected via USB-serial! - by nib0 - 09-24-2020, 08:17 AM
  Pinebook Pro Initial Impressions kunger 443 594,189 04-16-2024, 07:29 PM
  looking to buy one pinebook pro (mainland China) duanduan 3 2,343 03-21-2024, 07:44 PM
Last Post: wangyukunshan
  Cellular module for Pinebook Pro Lotech 1 427 03-05-2024, 05:40 AM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 324 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Sale my ANSI PineBook Pro cuthbertdavies 0 310 02-14-2024, 09:12 PM
Last Post: cuthbertdavies
  Compiling with -j6 on the Pinebook Pro (Overheat) KC9UDX 0 245 02-14-2024, 09:01 AM
  Pinebook Pro in EU for Sale - €90 jan_vdk 2 702 02-07-2024, 02:12 AM
Last Post: 23Ro
  Pinebook Pro for sale tomekdev 2 785 02-01-2024, 11:35 AM
Last Post: tomekdev
  uboot wont boot to SD card after upgrade jbradley419 7 916 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 310 01-16-2024, 09:17 AM
Last Post: jbradley419
