Wobbly USB-C connector?
Sorry if this is a FAQ; I searched and didn't see anything. Just got my first PinePhone and while charging after the first boot I noticed that sometimes if the cable is bumped (such as by picking up the phone while it's charging) I'll here the connect/disconnect notifications chatter a few times.  This doesn't always happen -- oddly enough, if I gently flex the end of the cable to test how much play it has it usually doesn't chatter -- but it does continue to occur randomly, a bit more often than I would like.
Is this normal?  There does seem to be a good deal more play than with other USB-C phones I've compared against.  Is there a special charging setup (e.g., a charging stand that fits especially well) or handling technique  needed to avoid damage?
Wobbly USB-C connector? - by pregier - 09-21-2020, 02:30 PM
RE: Wobbly USB-C connector? - by fernando_c_m - 09-22-2020, 01:00 AM
RE: Wobbly USB-C connector? - by pregier - 09-22-2020, 01:47 PM
RE: Wobbly USB-C connector? - by fernando_c_m - 09-23-2020, 01:10 AM
RE: Wobbly USB-C connector? - by preflex - 10-16-2020, 02:19 AM
RE: Wobbly USB-C connector? - by wibble - 10-16-2020, 10:22 AM
  USB-C connector Overheated and melted nickbenjones 2 1,365 05-26-2023, 06:16 PM
  GPS Antenna - external connector? GregH 14 11,767 09-09-2021, 09:24 AM
Last Post: HobanWashburn
  Fragile SIM card connector hakkou 1 1,841 08-25-2021, 07:44 AM
Last Post: wibble
  USB C connector loose? bceverly 3 3,005 08-10-2021, 09:44 AM
Last Post: c3l@
  Micro-USB 3.0 connector for the PinePhone? Peter Gamma 1 2,171 03-10-2021, 10:11 AM
Last Post: wibble
  broken connector-pin for the accu alwi 2 2,832 02-23-2021, 06:28 AM
Last Post: scholbert
  Main Board Swap: Camera connector problems tyha 5 4,749 11-19-2020, 06:25 PM
Last Post: pajux
Bug USB Type-C connector overmold conflicts with the back cover ngkz 1 2,899 05-10-2020, 12:19 AM
