Pinebook Pro Sleep/Resume bug: The (Kinda sorta) Good, The Bad, and the (Very) Ugly.
Hi all.
After sharing the same experience that @EverythingIsInput @tiagoespinha @Eight Bit @Abandoned Brain @axel and no doubt countless others have had. I joyously unboxed my shiny new Pinebook Pro a couple weeks back, spent a delicious evening enjoying that new laptop glow, closed the lid and went to bed happy.
Only to wake the next day to find in utter dismay that the battery was totally dead. Utterly. Drained. Had to do a full recharge cycle, which, even with the barrel plug takes quite a long time.
Lather, rinse, repeat until I checked here and figured out that sleep / resume just doesn't work and that many others have felt this pain.
So I went on a bit of a quest to try to understand the problem and see if I could discern a fix or at least a usable work-around.
So let's start with:
The (Kinda Sorta) Good
At least now I understand the problem Smile
First, I tracked down Strit, the Manjaro-ARM release manager who was incredibly helpful, informing me that he'd heard that the bug was actually a bug in the Trusted Firmware, and that he'd heard this on the Pinebook Discord/Matrix.
So, I went there and started asking around, and @CrystalGamma said that he understood the issue, but that he's working another project, and if the fix isn't in in about a month when his project completes, he'll dive in and help make that happen. He mentioned that @theotherjimmy had been the one working the fix but that he hadn't been around in about a month.
At that point @theotherjimmy popped up and very helpfully explained that yes, he's been stuck on the latest suspend/resume bug but in fact there are actually *4* related bugs that would need to be solved before end users can get this to work.
He also explained that the bug is in RockChip's vendor code and that he likely wouldn't have time for it for a while since his employer has him working other issues.
They both pointed out that the Git repository containing the firmware is here
but CrystalGamma pointed out that debugging these issues requires the audio jack to USB adapter from the Pine store, but also that this adapter *appears* to have the wrong voltage (5v as opposed to 3 and change volts) and as a result could damage your Pinebook Pro if you try to use it, so there goes any thoughts I had about trying to fix this myself Smile
The Bad
So, the bottom line is, for us end users, we essentially should abandon any hope that suspend/resume as we know and expect it will work anytime soon on the Pinebook Pro. We're talking at *least* months. Possibly longer.
Ultimately, Pine64 made it very clear that we were buying into an open source experiment here, not a polished product, so I bear no ill will against them in this, but I can't lie - I'm extremely disappointed. This situation diminishes the usefulness of the PBPro for me tremendously  - it means I have to shut down and power up from cold boot every single time I want to use the laptop.
At least, for the moment, I have figured out a really UGLY work around that makes me incredibly sad but at least keeps me from forgetting and draining my battery every time I walk away from the laptop for the day.
The (Very) Ugly
So, what I have done in order to semi-mitigate the situation is to configure KDE to shut the laptop down whenever the lid is closed. To say this isn't ideal is the understatement of the century, but what else am I going to do?
In order to do this, click the Manjaro button in the lower left or hit the Pine logo key on your laptop, and type "Energy Saving".
This will bring up a dialog with three 'tabs': "AC Power", "Battery" and "Low Battery".
Under "Button Events" I simply changed "Sleep" to "Shut down" for each of these categories, and that seems to the needful and at least keep the laptop from bleeding out overnight when its lid is closed.
In Closing - Just To Be Perfectly Clear
I knew I was taking a risk when I bought this laptop. Pine said in no uncertain terms that it was selling these at cost and that returns were only allowed for drop dead problems like a totally DOA unit.
I also recognize that this entire venture is an experiment in the spirit of open source - let's take some high value low cost hardware, assemble it in innovative ways and see what the community does with it.
All the people I spoke to about this were incredibly friendly, helpful and forthright. They've all poured blood, sweat and tears into this project and others, and I would ask that anyone who uses this to contact them please treat them with the utmost respect and deference.
I can't lie, I'm disappointed in a number of ways, but I continue to be on board with the experiment and will keep trying to use this hardware until I come to the conclusion that I am absolutely unable to do so.
Pinebook Pro Sleep/Resume bug: The (Kinda sorta) Good, The Bad, and the (Very) Ugly. - by feoh - 09-10-2020, 07:23 PM
  Debian on Pinebook Pro u974615 7 1,203 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 1,689 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,198 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,281 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 89,635 12-08-2023, 11:25 PM
  Boot Order in Pinebook Pro food 8 1,298 11-23-2023, 07:37 AM
  Sleep and external display - Are there any options? chris88233 7 1,783 09-04-2023, 09:03 PM
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 5,416 08-31-2023, 04:20 PM
Last Post: TRS-80
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,522 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
  Install deepin OS on pinebook pro wangyukunshan 4 1,629 08-07-2023, 01:12 PM
Last Post: myself600
